My car has 60,000 miles, I think is time to replace the fluid. has anyone used Royal Purple? What kind of fluid? Max Gear or Synchromax? any other brands I should consider? thanks for your help.
#2 (permalink) | |
QUOTE (JCPM @ Jun 7 2009, 11:05 AM)
I'm also a fan of AMSOIL products, but I wasn't happy with their manual lube in my transmission-- didn't seem to work well with the synchromesh and made the shifting slow and difficult.
2006 Mazdaspeed6 GT -- Black Cherry Mica, White/Black Interior, Moonroof, Compass/Auto-Dim Mirror, Satin Aluminum Fuel Door Glow-Shift Boost & Oil Temp. Gauges -- AEM Wideband UEGO Controller -- Slyfex AuxMod -- Denso ITV22 Spark Plugs -- CX-7 Antenna -- Redline Tuning QuickLIFT Mazdaspeed RX-8 Shift Knob -- TWM Short-Throw Shifter -- Speedie6 Turbo Inlet -- CP-E/HKS BPV Kit -- CP-E XCel Intake -- CP-E Turbo-Back Exhaust Car Chemistry Insert -- CP-E Engine & Rear Diff. Mounts -- Turbine Tech Diff. Mount -- Techna-Fit Brake Lines -- StopTech Slotted Rotors -- EBC Redstuff Brake Pads SPC Adj. Ball Joints -- RPM K-Spec Lowering Springs -- KONI Sport Adj. Shocks -- Rota SubZero Wheels -- Goodyear Ultra Grip Performance Tires<span style="color:#2E8B57">"AWD Driving: This vehicle has not been designed for the purpose of off-road driving or rallies. Do not attempt to drive over uneven or rocky surfaces, or across rivers."</span> |
#4 (permalink) | |
Stay away from RP, it is a GL-5 lube that isn't yellow metal safe. Redline MT-90 or Amsoil MTG are fine choices.
2007 T-Gray 6s MT 2008 Phantom Blue Mica 3s Hatch - AT, Stock |
Short answer, dont use the royal purple. Long answer, it seemed good when it was cold outside, except when the tranny itself was cold, but after it warmed with a few highway miles it seemed great. Now that its hitting 90 outside it is horrible, it is extra hard to go between gears. In fact i just ran a search on here to find out the exact redline product alot of other people on this site uses cause im gonna dump the RP crap and try Redline. Thats how i got on this thread, and why i felt the need to tell you not to waste the 60 or 70 something dollars like i did. and BTW jd42 and mariusvt thanks for listing what i was looking for...off to find some RL MT-90 now, ta ta.
Shawn |
ya....stay away from RP....IIRC markyb had 3 tranny failures due to that stuff. I've filled twice w/ the Red Line MT-90 and like it a lot
2003 Performance White 6s MTX, CPE CAI MAF-CI, Xtec 5000K HIDs, Superwhite LEDs, TB bypass, EGR mod, Iridium NGKs, 25% tint, clear sidemarkers w/ turn signal mod, brakelight mod, SU MM, MazdaSpeed Short Throw Shifter, Custom Exhaust: 12" glass pak resonator and axle-back Str8s, Flat Black painted bezels, Exedy Stage 1 clutch and Fidanza Flywheel, ceramic pads, Redline MT-90, Mobil-1 0W-20 and Mobil-1 Mercon V PS fluid |
#7 (permalink) |
Thanks everybody for the info, I have decided to go with AMSOIL products. I will change the transmission fluid today. Thanks again.
#8 (permalink) |
Is the Redline fluid blue? When I had a Subaru the big thing was smurfsblood, and I think it was Redline Shockproof to be exact, but cant remember.. Anyways that stuff ROCKED. I used half smurfsblood and half motul 75-90. Super smooth. If I decide to try the combo with my car Ill let yall know how it goes. Right now I just half some dino oil 75-90 in it from my shop when I did my axles and it pretty much sucks.
3.0 MTX 5-door, lowered on H-Techs, riding on Enkeis, wrapped in Bridgestones, gutted intake, no mufflers. Cant wait for some more MONEY!!! |
#9 (permalink) |
Have been using the Amsoil MTG for 25K now (100K on the car, 03 6i). I like it alot, no problems shifting in hot or cold temps (live in central CA so not too extreme 110 summer, 30 winter). I commute, just under 200 miles per day, some stop and go traffic.
2003 Mazda 6i, 5 speed, 103K only two mods: 1) Tinted all but the front window 2) Changed over to the spin on filter (because I HATED the cartridge!!!) |
#10 (permalink) |
I chucked Redline MT-90 in mine and after a few weeks now I must say that it is not as great as everyone makes it out to be. First few days it was great but by now it is really just like before. I'm thinking I will follow mr.tea's advice and go with synchromesh i believe it was....
I can also back Royal Purple as a good brand, however both RP and Redline do not ALWAYS have positive results, plus Redline's products just jacked up in price :P
2002 Mazda 6 Limited series 1 Manual 2.3L I-4 Australian Model (Jap Spec) 10:6 High Compression Current Mods: BC Racing Coilovers | Injen CAI | Advanced Timing | Dark Yellow Smoked Fog Lights | 18" Mazda RX-8 Wheels on Bridgestone GIII 225's | Raybrig 4500K Pure White Parker/licence/door Bulbs imported from Japan | Audiolink ipod Connection | Fluoro Orange Rocker Cover | Custom Grounding Kit | Breather Air Filter | Apexi Turbo Timer | PCV Oil Catch Can (Still need to install) | RDA Front Slotted Rotors | ACRE Super Fighter Pads | NGK Plug Wires | 6-SMD Red Interior Map Lights | Honda S2000 Gearknob Coming SUPER soon: HIDs (Freight Container Arriving Soon) | Front/Rear Strut Bar | Exedy Stage 1 Sports Organic Clutch | Exedy Lightened Flywheel Coming soon: F2 Supercharger kit | F2 Header | Custom 3" Catback Exhaust System with High Flow Cat | Complete Haltech Tune |
