My 2005 6S has 60K miles on it and I decided to change the transmission fluid from the Redline MT90 that had been in the car since I did that swap back when the car was new (I am the original owner). I ordered 3 quarts of Neo 75W90HD fluid from http://www.bakerprecision.com and when the shipment arrived the weather was relatively warm (especially for Massachusetts) so I did the fluid change.
With the Redline fluid I thought the gearbox was pretty slick except for the occasional crunchy 2-3 upshift. With the Neo fluid in the box every shift is super slick. 1 finger shifting is the norm for me (I don't have any short-shifter installed - it's the factory shift mechanism) and we have temps down around 20F this morning and the car slid in and out of gear nice and easily. One additional plus with the Neo is that driving at highway speeds in 5th gear my transmission is silent - no faint whine that I used to have with the Redline fluid. If I had to choose between Redine and Neo I would probably go with Neo again. The only reason that I wouldn't say 100% Neo is that I've had very good results with the Redline fluid for the past 3.5 years and only a week with the Neo. If the transmission continues to perform they way it is now though, it will be Neo from me for now on. The fluid change itself was a piece of cake. Jack up the car and support with stands at both the front and the rear so that it's "level" even though you can get under it. Open the fill plug with a 10mm hex key (I have the 3/8" drive set from Craftsman and 10mm is the largest). Then open the drain and let it drain. Put the drain plug back in (wipe any filings off the magnet end of the plug even though mine was clean) and start pumping in the fluid into the fill hold until it starts to seep out. |
#3 (permalink) | |
QUOTE (skiracer @ Aug 1 2009, 10:25 PM)
That stuff is damn good. I used it and the shop that put in the new clutch and Fidanza flywheel put Royal Purple in it. Huge difference. Ran the Royal purple for a few months and then put some Schaffers in it, that stuff is equally as good.
Anybody who tells you money is the root of all evil doesn't fucking have any. |
#5 (permalink) | |
QUOTE (itchyrichy @ Aug 2 2009, 02:00 AM)
If I'm reading it right, isn't "75W90 HD Competition Gear Oil" a GL-5 oil? I thought GL-5 in our transmissions was bad...
2005 6 GS Mtx. Black/Black, MS-CAI w\ Injen Cover, MS-Short Throw & Optimized Throttle Body. Neo Synthetic for MTX |
#7 (permalink) | |
QUOTE (joebrez @ Nov 9 2009, 07:42 AM)
#8 (permalink) | |
QUOTE (Drogos @ Nov 24 2009, 09:43 AM)
#9 (permalink) | |
QUOTE (joebrez @ Nov 24 2009, 08:52 AM)
which would be bad for our tranny ?? Might be smooth as hell but I don't care for it if my tranny goes bad in 20k miles or so. I don't have problems with my tranny at all and I testdrove Manual m6s that were an absolute pile of chunking crap in comparison to mine...so I don't want to screw up something that is not bad to start with. I do get some chunkiness (is that even a word ?? forgive me I am not a native speaker) in 1st and 3rd when cold but from what i read here it's the nature of our trannies. \Can someone jump in please and clarify the GL-5 thing ...thanks much EDIT: ok I got it the other way around I guess. GL2-GL6 would mean it is safe for trannies with those requirements. ..well DUH!!!
#10 (permalink) | |||||
QUOTE (justinhb @ Nov 9 2009, 05:44 AM)
QUOTE (joebrez @ Nov 9 2009, 08:42 AM) Quote:
QUOTE (Drogos @ Nov 24 2009, 09:43 AM) Quote:
QUOTE (joebrez @ Nov 24 2009, 09:52 AM) Quote:
QUOTE (Drogos @ Dec 17 2009, 08:22 AM) Quote:
GL5 is bad if it is sulfur based fluid.
