Go Back   Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum > Technical / Performance / Model > Mazda6 1st Generation (2002-2008) > Engine / Drivetrain > MTX Transmission Discussion
Old 01-18-2009, 12:27 AM   #1 (permalink)
Palmz43's Avatar
Send a message via AIM to Palmz43 Send a message via Yahoo to Palmz43
hey mazda 6 guys we have a GI but soon to b GB for a fix for the STS shifters...below is what TWM is going to be making...if you want to get in on it hit me up with a PM and ill send you a link to the forum that it is on.
hey guys i was talking to TGNY today and he had a great idea of having the bracket that the shifter assembly sits in made out of aluminum by TWM... key features would include a bracket that either clamps down or is screwed into place over top of the shifter cables plastic clips, which would stop the clip from popping out or moving around... Furthermore anyone with a short shifter has more than likely done the bolt mod to adjust the angle of the shifter cable, but the problem with this is the cable is not proberly secured into place and it tends to move around making shifting sloppy...To get around this problem TWM could make a spacer that clips into the bracket holder for the shifter cable and it would do exactly what the bolt mod did, but safely and with a secured cable properly clipped in (then the above mentioned bracket would then either clip in or be screwed in over top of it making it unable to pop out or move around)... The reason for the spacer is because me and TGNY thought it would be better to have an aluminum stock bracket made up then have the spacer as an add on for those with short shifters so both people with stock shifters and those with SS would be able to get it because i guess the problem is present for people with both types of shifters....
the white plastic thing is the shifter assembly that we want made out of aluminum
The bracket would go over top of this area that i have highlighted in red and either screw in or clip in
This is where the spacer would go in for anyone with a Short Shifter
here is a video of the problem
http://www.youtube.com/watch?v=KBLXNKyHCXc
2004 Onyx Black 6s Sport MTX
Performance:-Injen CAI, CP-E Engine Mount, SM Oil Catch Can, Racing Beat Rear Sway Bar w/ AWR Endlinks, Fluidampr Underdrive Crank Pulley(1 of 45), Custom Exhaust, Neo 75w90 HD Trans Fluid, Corksport SS Clutch Line, TB Coolant Bypass
Appearance:Apexcone 55W 8000k HIDs in lows, Apexcone 35 watt HIDs in fogs, PIAA Extreme Whites in Highs, Blacked Out Side Markers, Painted Engine Cover, Viper 5002 Security System, 5% Tint, 2006 Tail Lights, OEM Sport Grille, NRG Hood Dampers, De-badged, VG Shark Fin, Red LED Map Lights, Red accent lights, Enkei GTC 01 Hyper Black Rims wrapped with Yokohama S.Drive Tires, Alpine IVA-D106 In-Dash
Future mods:Sniper Tuning, NGK Iridium IX Spark Plugs, Stacker 8, Sniper Coils, MSDS Headers, AWR Passenger and Driver Mounts
Palmz43 is offline   Reply With Quote
Old 02-20-2009, 10:52 PM   #2 (permalink)
sstaft's Avatar
Send a message via Yahoo to sstaft
Interesting. I was just looking at the TWM site and thinking of buying the shift kit. However if there is a problem with the short shifters, then maybe I wait to see where this is gonna go with a plate instead
sstaft is offline   Reply With Quote
Old 03-07-2009, 02:11 PM   #3 (permalink)
docgoku's Avatar
Send a message via MSN to docgoku
I've already got the bolt mod in.... but it could use a re-greasing at this point....
JH
SOLD - 04 Mazda 6s SportWagon - Glacier Silver - 5M
http://www.cardomain.com/ride/757874
docgoku is offline   Reply With Quote
