Go Back   Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum > Technical / Performance / Model > Mazda6 1st Generation (2002-2008) > Engine / Drivetrain > MTX Transmission Discussion
Old 12-30-2008, 09:55 AM   #1 (permalink)
neon_guy's Avatar
Send a message via AIM to neon_guy Send a message via Yahoo to neon_guy
So, I've known that my 3rd gear wasn't planning on hanging around for the duration of my ownership, and it finally went about a week ago. I can put the vehicle into 3rd gear but it will not stay in 3rd. I called Vincent Mazda to see if they could fix it and they gave me the whole run-around about how it could be a million things and they'd have to keep the car for a few days and blah blah blah blah. After growing tired of going back and forth with them, I found out what a reman tranny would cost. So, is there any cheaper way to go about this or is the new tranny the best way. I probably won't do that just cuz I don't really NEED 3rd gear, but if there's an easier way to fix it (read cheaper) I may be open to it. Any help is MUCH appreciated.
edit: oops. I just realized I put this in the wrong section. Mods, feel free to move it. My bad. I was writing kinda quick cuz I'm at "work".
Pssssssft!!!! Zoom Zoom BOOM!!!!
Yeah. That's about right.
neon_guy is offline   Reply With Quote
Old 12-30-2008, 11:16 AM   #2 (permalink)
jd42's Avatar
Paying a dealership to tear down and rebuild a transmission is going to cost and arm and a leg in labor. (I know, I had that done with an Audi transmission.) Transmission internals are pretty tricky to get just right, and chances are you'll never be perfectly satisfied with the results afterwards, either.
I suggest you do some hard searching to see if you can find a lightly used or rebuilt transmission for a reasonable price. The labor to swap out a gearbox will be a lot less than tearing into the internals. Plus, if you get a rebuilt unit, you may be able to swap yours for a core charge and reduce your cost.
I don't know if there are any good aftermarket transmission options for the Mazda6, but that is another route you could explore.
Good luck!
Old 12-30-2008, 05:41 PM   #3 (permalink)
Administrator
Mazda Gremlyn's Avatar
If you're at all mechanically inclined you can either replace the tranny yourself or take it apart and replace just 3rd gear, but the transmissions in the 6 are horrible to get to, and I think I would pay someone else to do it just based on that. As has been said, provided that the shifter cables are still nice intact, there really isn't much else it could be. Is there any grinding noise when going into or it coming out of 3rd?
2004 Mazda6s MTX: Injen/CP-E Tunable, Espelier Lowering Springs, Racing Beat Sway Bars, 6gunrocket endlinks
1988 323 GTX: It LIVES!!
Mazda Gremlyn is offline   Reply With Quote
Old 12-30-2008, 05:56 PM   #4 (permalink)
neon_guy's Avatar
No sir. I think I know what it is. I doubt I'll replace it just because I don't feel like putting the money into it. I still have 1,2,4,5 & R. Really, I only NEED 2nd, 4th, and Reverse. So, as long as those are in tact, I'll probably just ride it as is.
Old 12-30-2008, 08:42 PM   #5 (permalink)
Administrator
Just be careful, if one gear went others may follow as you don't know WHY that gear went in the first place. You don't want to be driving along and lose an 'important' gear.
Old 12-31-2008, 09:47 AM   #6 (permalink)
neon_guy's Avatar
Yeah. I've been taking it easy for quite some time now. I know 3rd gear was not going to last probably last summer some time. It's been kinda sloppy and loose since late 07. When the car is no longer driveable, I'll either get a 300C or a G35. In THAT scenario, I'll probably just hold on to the Mazda and fix the tranny should I decide I want to spend 1500 for a "winter beater". It'd be, HANDS DOWN, the best "winter beater" I've ever owned at that point. So, we'll see what happens.
Old 02-10-2009, 10:02 PM   #7 (permalink)
I had the same problem except mine was 5th then 3rd now 1st... SON OF A B%$#@. Car is currently in the shop. i should find out what’s wrong with it tomorrow. I’m mentally preparing myself to be raped with no lube or dinner afterwards. I hate car mechanics that make stuff up!!
Dre2068 is offline   Reply With Quote
Old 02-10-2009, 10:21 PM   #8 (permalink)
Send a message via AIM to MicaBlackMS6
Do you have the 6i or 6s. Here is a trans for $400 from a 6s.
http://forum.mazda6club.com/index.php?showtopic=108951
Beauville pronounced Booville
<div class='quotetop'>QUOTE (KFC_Or_Bust @ Feb 8 2009, 03:30 AM) <{POST_SNAPBACK}>
...Why do I even waste my time trying to talk sense and realistic thoughts into your guys's heads?
Kingsford? Lol, you guys are like 3 year olds, entertained by the simplest thing.
<div class='quotetop'>QUOTE (G. Seereez @ Feb 8 2009, 04:04 AM) <{POST_SNAPBACK}>
KINGSFORD isn't simple, you are.
MicaBlackMS6 is online now   Reply With Quote
Old 02-11-2009, 09:11 AM   #9 (permalink)
neon_guy's Avatar
I don't have 5th gear anymore either. I'm not sure if I want to spend the money on fixing it right now though. I know I'm not selling it any time soon, but I don't know if I really want to pay to fix it. I'll check out that tranny tho.
