Half Shaft Replacement - Driver's side - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 7 (permalink) Old 05-22-2008, 04:33 PM Thread Starter
Thumbs down
I'm replacing the driver's side axle on my 6. I can't get the thing to seat, the clip isn't allowing it to go all the way in and seat. What is the best way to seat this thing? I hate to beat on it and break something...need help ASAP please!
jeez is offline
post #2 of 7 (permalink) Old 05-22-2008, 10:37 PM
rubber mallet on the end of it only way
2003 6S 5 speed. 116000 miles. fidanza flywheel. specd stg 2 clutch . air box mod. rb springs and tok's for shocks. msds headers full exhaust with magnaflow resonator and dynomax super turbo's rb sway bars. ebay front strut brace 17x7.5 with 235 45 17 azenis and oh ya there is a lil headwork
235 whp 219 wtq (avg of 3 dynojet dynos) rpm rear and side smokes markers 8k 35w hids in lows and fogs. try as you might but you just cant keep up.
midastech390 is offline
post #3 of 7 (permalink) Old 05-27-2008, 06:23 PM Thread Starter
rubber mallet on the end of it only way[/b]
Well, the rubber mallet did not work. I be the living crap out of that freaking driveshaft. Took it back to the Drive Shaft King....BTW...they are AWESOME!! They removed the clip and spring loaded the first CV joint. Thing works like a champ now...no leaks, no noise at all..perfect.
jeez is offline
post #4 of 7 (permalink) Old 05-27-2008, 07:42 PM
SANDMAN.3's Avatar
Groans: 19
Wow your drive shaft too! It seem like it's the season for drive shaft repairs/replacement. I just recent replaced my driver side halfshaft assembly also and IIRC there's like 2 others from this forum experiencing same issue. Could there be some kind of manufactured defective shaft issue to certain VIN? Drive shaft should last much longer than ~77,000 miles!
SANDMAN.3 is offline
post #5 of 7 (permalink) Old 05-27-2008, 11:36 PM Thread Starter
Mine broke because of dumbass disease. I yanked on the end of it in a moment of RAGE cuz it would not come out and dislocated both cvjoints.
jeez is offline
post #6 of 7 (permalink) Old 05-31-2008, 11:17 PM
bluestreak6's Avatar
Send a message via Yahoo to bluestreak6
i recently replaced a shaft on a atx but still................
Oh yea i DO own a Mazda don't i!!!!!!!!
bluestreak6 is offline
post #7 of 7 (permalink) Old 02-25-2011, 02:07 PM
what do you mean they removed the clip then spring loaded it first?
i am having troubles with mine, getting it back in.. I tried re-bending the clip.. which didn't do much because I had to spread it over the axle shaft to get it to go back on.
Mcdouble is offline
