Removing Rear Seat... How? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 6 (permalink) Old 07-27-2012, 02:28 PM Thread Starter
Quoted: 58 Post(s)
I have tried to search the forum, but came up empty.
I need to run a wire from the front to back of my 2009 GT.
I need to know the correct way to remove the rear seat to make it easy to fish the wire through to the trunk.
Thank You,
Tom
tommyz23 is offline
post #2 of 6 (permalink) Old 07-27-2012, 02:40 PM
Quoted: 11 Post(s)
how thick is the wire? i have 1/0 gauge running under the door sills instead of removing the seat. works fine there.
2009 Mazda 6 - Performance White V6
Ankit69 is offline
post #3 of 6 (permalink) Old 07-27-2012, 03:38 PM
DPFISUMS6's Avatar
Quoted: 10 Post(s)
Bose subwoofer replacement
maybe this helps... check the first step of his install process. "Removing rear seat"
VRM 2006 MS6 GT #517
AP V3 - Self Tune in Progress - ACT/pedal reinforced - H&R Springs - JBR 80a RMM - DREAD - TWM Stg 2 - Turbosmart BV - Denso20s - Hawks - SPC BJs - CS SS Clutch Line - Defroster POD/PS Boost Guage - RED Footwells - CAR LED & Brake Mod - LED Turns & all 194s -Smoked Side Markers - Nokya Yellow H11s w/MOD Rockford 200w Amp/12" Sub - AUXMOD
Plasti Dipped Lots of Stuff - Redline and Royal Purple
DPFISUMS6 is offline
post #4 of 6 (permalink) Old 07-27-2012, 04:32 PM
Quoted: 11 Post(s)
Sorry read that way to quick. Thought it said driver seat.
Good guide. If you need any more help just let me know. It's not hard to remove it, harder to put it back in.
Ankit69 is offline
post #5 of 6 (permalink) Old 07-27-2012, 11:59 PM Thread Starter
Quoted: 58 Post(s)
PICTURES Removing the rear seat cushion 2009+ Mazda 6
OK,
I went ahead and removed it before I saw the answers on the site.
I found there are little slide latches under the front of the seat cushion. They would be located between the outboard passengers feet.
It looks interesting under the seat. Some kind of sound deadening.
Pictures:
Release Latch:
Pushing the Release Latch:
Seat Cushion Removed:
Sound Deadening Material:
Side Bolster Attachment Bolt:
Hope this helps... Maybe a Sticky...
Tom
tommyz23 is offline
post #6 of 6 (permalink) Old 07-28-2012, 02:30 AM
Quoted: 11 Post(s)
good job. and that is some "sound deadening" material. crappy ones =/
Ankit69 is offline
