I just bought a 2009 Mazda 6i. I ask to get the auto dim rear view mirror and the heated auto dim side mirrors. The ordered the parts and when they went to install. The side mirrors will not work on my car (not pre-wired for ED door mirror kit) They don't tell you this when you order them. Hey the dealer didn't even know. The installation instructions have you check your rear main harness label to find out. I really want heated mirrors. anybody have any ideas.
Thanks |
Lots of guys I know did this on CR-Vs.
If they'll fit, and they're driven like most cars, what you need to do is this: wire-fish a pair of speaker wires (call it 18ga) All you'll need from there is a switch and a 12v relay. Can you post a picture of the rear of the mirrors? I'll help if I can. -Ernie
Car Domain Page with all Mods and upgrades: http://www.cardomain.com/ride/3386678 (Not sure why it gets lower ratings than stock and rims-only cars . . . maybe I need a "TYPE R" badge) Personal Page (stereo changeout writeup): http://www.cynicalivy.com/MAZDA6/ |
#3 (permalink) | |
QUOTE (Ernie @ Oct 29 2009, 09:16 PM)
Thanks Here are the pictures hope it helps Tosem ![]()
Okay, I can't tell for sure, but it looks like there's only 2 leads; if that's the case, those are your target.
If not, please give me a higher res shot of the black side of that harness and that inside (top in this picture) part of the mirror. To bench test (if there are only 2 wires): Get an inline blade fuse (10amp should do it) and for about 10-20 seconds, "plug it in" ( to 12V, see below). The surface of the mirror should get slightly warm in this time. Obviously unplug it quickly if anything odd happens . . . Now, most people don't have a 12v house inverter . . . what I usually do is buy a cigarette lighter extension cord, cut it in half, then split the wires (so you have a ground and hot) and fuse the + side; use small wire nuts for in-car bench testing. If you don't have a multimeter, get one, they're hugely helpful in telling what wire is what when poking around inside electronics. I'll see if I can hunt up a friend of mine's write-up for his CR-V from another board. -Ernie
He said they're heated and auto dim so there will be more than 2 wires.
If he has blind Spot, there will be at least 4 if they all ground to the same wire. Could be as many as 6 if grounded separately. *looks in wiring book* Blind Spot Monitoring Wires Driver Side + = W/R - = B Pass Side + = W/B - = B Dimming (both sides) Y/L BR/L Heated Driver Side + = P/B - = B Pass Side + = P/O - = B
2009 Mazda 6 GT in Sangria Red. |
what is the location of the rear harness label that tells you if its ready for the mirrors? what is the label information that we are looking for?
#7 (permalink) | |
QUOTE (CU2003 @ Feb 8 2010, 02:51 PM)
2010 touring six speed. |
#8 (permalink) | |
QUOTE (Deadstick @ Feb 8 2010, 01:03 PM)
<span style="font-family:Book Antiqua"> "For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and there you will long to return". Leonardo da Vinci</span> |
#9 (permalink) | |
QUOTE (bloodburn5 @ Feb 8 2010, 06:12 PM)
You can at any rate install the inside mirror w/compass/homelink. There is a choice of two different harness's, one that is plug and play, and one that terminates with three connections - switched power, constant power, and ground. In fact, you could just pull those conductors out of the plug and play harness also. You will loose the reverse function (Mirror goes to full reflection when reverse is selected) and integration with the side mirrors. I would be surprised if you really had the "bad" number on your harness. You pulled the scuff plate off and found the harness number?
