I was washing my car last week and noticed that there is a foam/rubber seal that is coming out from between my windshield base and my dash. My initial instinct was to just get a screwdriver and force it back down, but I was going to the dealer for another issue so figured I would mention it. Thankfully they are having a Factory rep out at the dealer tomorrow and they wanted my car to show him the problem. The dealership figures they will either have to remove the windshield or the dash and replace the seal. The way it looks through the windshield it appears to be an excess amount of seal exposed. Here is a picture (sorry its from my cell phone)
#2 (permalink) | |
QUOTE (pwm72 @ Aug 31 2009, 07:09 PM)
Dealer (Martin Mazda - Newark DE) called me back today. Factory Rep told them to keep the car overnight and pull the dash, they ordered a new rubber strip for a Mazda RX8 (of all things) to replace the old one. They suggested that the rubber seal from the RX8 has adhesive on one side so it should not work its way out again. We'll see! I pick up the car tomorrow night. I hope I don't start getting dash rattles as a result of this!
Got the car back it it looks good. They pulled the dash pad and replaced the foam strip. It was covered under warranty, but the invoice said it was a $267.00 repair! That's nuts. Thank God for warranties.
Hypothesis is that the adhesive on the foam (apparently it did have adhesive on it) had failed and with the car in the sun, it just "expanded" out of the joint. Martin Mazda in Newark DE has a decent service department...I think many others would have just shoved it back in and called it a day. These are the parts that were replaced for reference: F151-55-162 Tape, seal F151-55-163 Tape, seal Repaired as per Mazda Factory Rep. |
#6 (permalink) | |
QUOTE (pwm72 @ Sep 2 2009, 10:38 PM)
2006 Mazdaspeed6 GT -- Black Cherry Mica, White/Black Interior, Moonroof, Compass/Auto-Dim Mirror, Satin Aluminum Fuel Door Glow-Shift Boost & Oil Temp. Gauges -- AEM Wideband UEGO Controller -- Slyfex AuxMod -- Denso ITV22 Spark Plugs -- CX-7 Antenna -- Redline Tuning QuickLIFT Mazdaspeed RX-8 Shift Knob -- TWM Short-Throw Shifter -- Speedie6 Turbo Inlet -- CP-E/HKS BPV Kit -- CP-E XCel Intake -- CP-E Turbo-Back Exhaust Car Chemistry Insert -- CP-E Engine & Rear Diff. Mounts -- Turbine Tech Diff. Mount -- Techna-Fit Brake Lines -- StopTech Slotted Rotors -- EBC Redstuff Brake Pads SPC Adj. Ball Joints -- RPM K-Spec Lowering Springs -- KONI Sport Adj. Shocks -- Rota SubZero Wheels -- Goodyear Ultra Grip Performance Tires<span style="color:#2E8B57">"AWD Driving: This vehicle has not been designed for the purpose of off-road driving or rallies. Do not attempt to drive over uneven or rocky surfaces, or across rivers."</span> |
#7 (permalink) | |
QUOTE (jd42 @ Sep 3 2009, 06:02 PM)
Chuck's 2003 Hyundai Tiburon GT - Eaton Supercharger and bolt-ons and 2009 Mazda 6 GT - Auto EXE springs, Rotora BBK, tinted windows, cf engine cover
#8 (permalink) |
Add me to the list. I just looked at my windshield and notice the foam is up about a 1/2" in one spot. I wonder if enough cars have the problem they will issue a TSB.
#9 (permalink) |
Mine isn't sticking out quite as bad, but I am certain it shouldn't be visible at all. So I guess you can also add me to the list. Does any one know what the foam is actually used for?
#10 (permalink) | |
QUOTE (FFEMT6 @ Sep 6 2009, 01:22 AM)
