Go Back   Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum > Technical / Performance / Model > Mazda6 1st Generation (2002-2008) > Models / Trim
Old 06-21-2009, 10:00 AM   #1 (permalink)
I have a issue with my 2005, I hit the unlock button and the driver door doesnt open. Im assuming the motor is bad, does anybody have a part number for that? Thanks.
cake96861 is offline   Reply With Quote
Old 06-21-2009, 10:14 AM   #2 (permalink)
Send a message via AIM to sp33dy6
maybe u accedently put it on child lock? or sumthing of that nature.. or maybe there is sumthing stuck with the switch? deff not the motor
ko4 2 GT3076
BIG POWAAA
sp33dy6 is offline   Reply With Quote
Old 06-21-2009, 05:04 PM   #3 (permalink)
kpjimmy's Avatar
Send a message via AIM to kpjimmy
QUOTE (sp33dy6 @ Jun 21 2009, 10:14 AM)
maybe u accedently put it on child lock? or sumthing of that nature.. or maybe there is sumthing stuck with the switch? deff not the motor[/b]
Theres no child lock on the drivers side, only the rear doors. I have had my lock go out on me on my tribute but not on the 6.
I would unfortunately go to the dealer and check it. It can either be the lock mechanism on the door or the actuator that operates the opening and closing.
I assume you can still use your key? If so then it could be the actuator. But get it checked by the dealer or local mechanic to be sure.
kpjimmy is offline   Reply With Quote
Old 06-24-2009, 03:16 PM   #4 (permalink)
Crimsonmt's Avatar
Have you ever removed the door or the part around the lever on the inside. I have forgotten to plug the lock back in sometimes and that jacks up the door. It would be the small white clip that plugs into the lock and unlock part of the door. Just a thought.
`05 6i Hatchback ~ Glacier Silver ~ Blacked Out Emblems, lights and interior ~ AEM CAI ~ Opt TB ~
Crimsonmt is offline   Reply With Quote
Old 07-12-2009, 08:54 PM   #5 (permalink)
Well when I said stuck it still moves a little, sometimes it will lock barley, but just about always never unlock. Most of the times the lock just moves a little. I took the door panel off and wanted to see if anything was binding it. No luck. So what is the cable from the lock going into called, I think that may be bad. Thanks.
