Go Back   Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum > Technical / Performance / Model > Mazda6 2nd Generation (2009-Present) > Models / Trim
Old 04-20-2009, 09:23 AM   #1 (permalink)
Is there anyway to have an iPod and the sirius operational? Iknow that the sirius uses the Aux plugin on the back of the receiver, but is there a special adapter i can use?
loremusic152 is offline   Reply With Quote
Old 04-20-2009, 09:40 AM   #2 (permalink)
jd42's Avatar
QUOTE (loremusic152 @ Apr 20 2009, 09:23 AM)
Is there anyway to have an iPod and the sirius operational? Iknow that the sirius uses the Aux plugin on the back of the receiver, but is there a special adapter i can use?[/b]
On the 1st gen Mazda6, satellite radio uses the CD changer port on the radio. The AuxMod can still be used, as that plugs into the media expansion port (tape/MD): http://forum.mazda6club.com/index.php?showtopic=30878
I don't know if the AuxMod is compatible with the 2nd gen models. If it is, that might be the solution.
Old 04-21-2009, 01:36 AM   #3 (permalink)
michaelsteinbach's Avatar
Send a message via ICQ to michaelsteinbach Send a message via AIM to michaelsteinbach Send a message via MSN to michaelsteinbach Send a message via Yahoo to michaelsteinbach
I have Sirius and iPod (integrated) connected with no problem.
~Mike
michaelsteinbach is offline   Reply With Quote
