Clock (Display) is going out... Anyone seen this? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 26 (permalink) Old 01-09-2009, 02:06 PM Thread Starter
It seem the clock in my wife's 2004 6i is being flaky. The illuminated parts of the time/temp/words will come and go. It can be fixed temporarily if it is bumped or hit to the display. The fix works usually only for a few minutes.
[attachment=40458:2004.maz...a6.clock.jpg]
Has anyone else had this issue? I am tempted to dive in and check the connections for this display, but I've heard that tearing into this console can be a trying process.
Anyone know if there is a decent aftermarket replacement or is this a dealer only part.
Thanks
James
bigjimcfh is offline
post #2 of 26 (permalink) Old 01-10-2009, 01:14 AM
smokeU6s's Avatar
Send a message via AIM to smokeU6s
I havent heard of anyones display going.... the M on my shift area usally doesn't illuminate and I had once the illumiation for the A/C Speed go out. Could be a failing fuse. I would check that 1st since its a far easier thing to replace, otherwise find a good weekend when you got shit to do
All Black Mazda6s 04 ATX 5door | Bose | Moonroof | CP-E MAFci Intake | Painted Yellow Calipers | Magnaflow catback | B&M tranny cooler | Magnafine Transmission Filter | Anzo Clear Side Markers | Weapon X Coil on Plugs
smokeU6s is offline
post #3 of 26 (permalink) Old 01-10-2009, 10:12 PM
QUOTE (bigjimcfh @ Jan 9 2009, 01:06 PM)
Thanks
James[/b]
My 2005 recently started doing this too.
FlyersFan is offline
post #4 of 26 (permalink) Old 01-11-2009, 07:25 PM
MonoxideChild's Avatar
Quoted: 44 Post(s)
Groans: 66
iTrader: 2 reviews
mine been doing that for awhile.
this has been brought up, and alot of other members mentioned they had the same problem.
MonoxideChild is offline
post #5 of 26 (permalink) Old 01-13-2009, 11:02 AM
mine does it as well. it only does it in the winter though. i usually just hit the dimmer button off and on a couple times and it works fine then.
03 sport 6, AEM CAI, H&R springs, custom painted interior, 18" Konig Hotswaps, euro cluster cover, cf trunk
emc1220 is offline
post #6 of 26 (permalink) Old 01-17-2009, 09:03 PM
stevieb's Avatar
i have this issue, mines only where it shows the time. 7:00 shows as 1:00. it started cutting off about 2 months ago... how do i fix this?
2003 Red metALLic mazda 6i 2.3 MTX
5% Tint / 5 brake Light mod / SMOKED side markers / LED interior lights-exterior lights / Tein H Tech Springs / OEM Appearance kit / 10" Audiobahn subwoofer / 1600W boss amp / OEM fogslight / Otto 10000k HID kit / OEM exhaust tips / custom paint OEM grill / blackout emblem / remove side guards / MSP6 WHEELS / AirBox Mod / painted foglight housing / Advance Timing / TWM short shifter / Blackout tail/ TienBasicCoilover/Bosch platinum fusion spark plugs/SPC balljoints/angel eyes/Smokes tails/smoked reflectors/blackout headlights/-
stevieb is offline
post #7 of 26 (permalink) Old 01-17-2009, 09:10 PM
Quoted: 44 Post(s)
Groans: 66
iTrader: 2 reviews
soo you will end up like mine, and not be able to make out anything really. lol
post #8 of 26 (permalink) Old 01-17-2009, 11:02 PM
Administrator
Mazda Gremlyn's Avatar
Mine started doing it mid last year, I figure at some point I'll just replace it. Getting into the dash isn't too bad, just be prepared to take a while your first time.
2004 Mazda6s MTX: Gone...
Mazda Gremlyn is offline
post #9 of 26 (permalink) Old 01-22-2009, 10:48 PM
its not too bad, 4 screws and a bolt to get the radio out. There's two connections to check, the one behind the head unit and the one on the LED itself. Good luck! if nothing else, PM MazmartSheldon about a replacement. I'm sure he can hook you up.
foobz is offline
post #10 of 26 (permalink) Old 01-25-2009, 03:53 PM
HerronScott's Avatar
Quoted: 145 Post(s)
I have a 2004 and mine also lost segments last year. I had it replaced under extended maintenane coverage.
Scott
2004 Mazda 6s GT MTX sports package
HerronScott is offline
The Following User Says NO Thank You to HerronScott For This Un-useful Post:
jcf6288 (12-06-2012)
