Go Back   Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum > Regional > USA > Mid-Atlantic
Old 09-14-2009, 11:16 AM   #1 (permalink)
Hey guys we want to do our first official dyno day on oct 17-18. You will get 3 pulls with your AFRs. This will be an all day event so come out and enjoy yourself. We ill have food and drinks there as well. This, if you didn't know is an AWD dyno as well. Also if you have not come by to see our shop you can take a look at what we will be to a street near you. This will be an all day event from 9am until!!
Any other question PM me...
Address is
6792 mid cities ave
beltsville maryland 20705
Just around the corner from CPE!!
CPE catless DP// CPE catback//CPE standback// SRI// ETS top mount// megan springs// turbine tech diff mount//carrilo rods//cp pistons bored .20 over//cometic head gasket/ arp head studs// carrilo crank bolts// balance shaft delete// ported turbine housing// 4" surge compressor housing//port polished bowl port 3 angle valve job// porting intake // 3' inlet and intake// custom FMIC// koni yellow adj ft and rr// SU MM//tial external wastegate 38mm// PG manifold//spec 2+ clutch and stock flywheel// previous info current weight 3410lbs// 260hp 284tq// best qtr. 13.2@103// RECORD BEST 60ft 1.71 Co-Owner and head mechanic
charles is offline   Reply With Quote
Old 09-14-2009, 07:14 PM   #2 (permalink)
yoichi's Avatar
My car better be done by then!!
Built Motor
344/356
yoichi is offline   Reply With Quote
Old 09-18-2009, 02:39 AM   #3 (permalink)
Qwik6's Avatar
Sweet. Less than 3 hours from me. Might have to take a little drive. Will you guys be offering any tuning for this day or just dyno's?
Qwik6 is online now   Reply With Quote
Old 09-18-2009, 11:52 AM   #4 (permalink)
QUOTE (Qwik6 @ Sep 18 2009, 07:39 AM)
Sweet. Less than 3 hours from me. Might have to take a little drive. Will you guys be offering any tuning for this day or just dyno's?[/b]
There is a tuning day for some probes on saturdays so if you want to buy in on the dyno time they are getting then we can have jason(dadasracecar) tune your car on saturday. Sunday is just dynoing.
Old 10-19-2009, 01:12 PM   #5 (permalink)
Just wanted to say thank you to those that came out to our Dyno Day. High number for the day was around 350WHP from a 2010 SS Camaro. The Mustang heartbreaker dyno definitely broke out the humble stick Sunday. LOL
White Water Pearl MazdaSpeed 6
y2kc0wb0y is offline   Reply With Quote
