#2 (permalink) | |
QUOTE (y2kc0wb0y @ Aug 4 2008, 08:32 PM)
whats up 2nr??
CPE catless DP// CPE catback//CPE standback// SRI// ETS top mount// megan springs// turbine tech diff mount//carrilo rods//cp pistons bored .20 over//cometic head gasket/ arp head studs// carrilo crank bolts// balance shaft delete// ported turbine housing// 4" surge compressor housing//port polished bowl port 3 angle valve job// porting intake // 3' inlet and intake// custom FMIC// koni yellow adj ft and rr// SU MM//tial external wastegate 38mm// PG manifold//spec 2+ clutch and stock flywheel// previous info current weight 3410lbs// 260hp 284tq// best qtr. 13.2@103// RECORD BEST 60ft 1.71 Co-Owner and head mechanic ![]() ![]()
#4 (permalink) | |
QUOTE (2nr @ Aug 4 2008, 08:28 PM)
when i out you then you will be like and i will be at the timing booth getting my timeslip after i have beaten you doing this while you are behind me doing this And then when you line up with me and i pull another 1.71 60ft on you, you will look over and you will see me like this and when we get back in the pits after your lose i will do this so you know who has just be OWNED!!!!! LOL see you friday!!
#6 (permalink) | |
QUOTE (charles @ Aug 4 2008, 06:29 PM)
2008 BMW 335i 4dr 6MT w/ sport package, black/black
#7 (permalink) | |
QUOTE (2nr @ Aug 4 2008, 11:33 PM)
We are 1 and 1 at the track!!!
#8 (permalink) | |
QUOTE (charles @ Aug 4 2008, 07:47 PM)
^^^^ We I'm out....and cannot even go to start another grudge. Laura's mother is turning 70 on Friday so we'll be having dinner at Willow. Talk about getting owned. Nah, she's a great lady and I'm honored.
White Water Pearl MazdaSpeed 6 |
#10 (permalink) | |
QUOTE (2nr @ Aug 5 2008, 10:28 AM)
