Go Back   Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum > Regional > USA > Mid-Atlantic
Old 07-15-2008, 06:25 AM   #1 (permalink)
2nr
2nr's Avatar
Send a message via AIM to 2nr
Just as the title says... anyone care to join me?
2nr is offline   Reply With Quote
Old 07-15-2008, 09:17 AM   #2 (permalink)
jvoss65's Avatar
QUOTE (2nr @ Jul 15 2008, 06:25 AM)
Just as the title says... anyone care to join me?[/b]
I can't make it but am looking forward to hearing your results. Is the flash the only thing you have changed since your last trip to the track? I would love it if you can put together before and after numbers.
06 Blackcherry Speed6 GT
Engine - CP-E CAI, HKS BOV, CP-E FMIC, CP-E catted DP, CP-E Nviscid TIP
Drivetrain - CP-E wishbone mount, TT diff mount
Suspension - RPM Kspec springs, Koni FSD shocks, SPC adjustable ball joints, Whiteline rear swaybar, Mazdaspeed Rays forged wheels
Brakes - Rotora rotors, EBC redstuff, Techna fit SS brake lines, Super blue fluid
Electrical - Trunk battery relocation
jvoss65 is offline   Reply With Quote
Old 07-15-2008, 01:11 PM   #3 (permalink)
QUOTE (jvoss65 @ Jul 15 2008, 01:17 PM)
I can't make it but am looking forward to hearing your results. Is the flash the only thing you have changed since your last trip to the track? I would love it if you can put together before and after numbers.[/b]
I am going to try and make it so that there will be 2 flashed cars there!! with pretty much the same mods. Also tell your buddy with the 350 nizmo to come also!!
CPE catless DP// CPE catback//CPE standback// SRI// ETS top mount// megan springs// turbine tech diff mount//carrilo rods//cp pistons bored .20 over//cometic head gasket/ arp head studs// carrilo crank bolts// balance shaft delete// ported turbine housing// 4" surge compressor housing//port polished bowl port 3 angle valve job// porting intake // 3' inlet and intake// custom FMIC// koni yellow adj ft and rr// SU MM//tial external wastegate 38mm// PG manifold//spec 2+ clutch and stock flywheel// previous info current weight 3410lbs// 260hp 284tq// best qtr. 13.2@103// RECORD BEST 60ft 1.71 Co-Owner and head mechanic
charles is offline   Reply With Quote
Old 07-15-2008, 02:10 PM   #4 (permalink)
2nr
2nr's Avatar
Z boy will most likely be there but not running.
Jvoss- the new mods since last time will most likely make a difference(Standback). But if I go a lot faster then a 13.4 we shall know what caused it.. .lol
Old 07-16-2008, 01:52 AM   #5 (permalink)
dan3381's Avatar
Send a message via AIM to dan3381
What time are you guys going down? I wouldn't mind coming down and meeting you guys. I might even take a couple runs but I doubt I will be in the low 13s.
Im in Northern MD, is there any one that I would be able to meet up with and follow down?
06 mazdaspeed 6 GT velocity red mica Going to a new home.
Replaced by a 07 Dodge Ram HEMI/Laramie
dan3381 is offline   Reply With Quote
Old 07-16-2008, 06:25 AM   #6 (permalink)
2nr
2nr's Avatar
The track opens at 6:30 p.m. and stays open until the racing is done.... the cost is $20 to run and $10 to watch
Old 07-16-2008, 09:02 AM   #7 (permalink)
jvoss65's Avatar
Charles and 2nr, don't forget a helmet. You'll be running fast enough to require one
Old 07-16-2008, 12:02 PM   #8 (permalink)
Hey 2NR i am off friday so i can be there at 6:30 so that i can get some runs in this time!!!
JV i will have my helmet in my car tonight so that i don't forget. I am also going to change my oil tonight since i have not changed it in 10,000 mile FTL!!!
Old 07-16-2008, 01:41 PM   #9 (permalink)
2nr
2nr's Avatar
JV, we have needed helmets for a long time now.... anything that runs 13.99 and faster requires it per NHRA and IHRA.
Charles.... make sure you bring your A-game too... lol
Old 07-16-2008, 02:06 PM   #10 (permalink)
QUOTE (2nr @ Jul 16 2008, 05:41 PM)
Charles.... make sure you bring your A-game too... lol[/b]
Record breaking time anyone? Of course i will be ready!! Might delete somethings along the way!!!
