ok guys with the upcoming flash coming out and all the dyno data that has been provided i am quite sure that you might want see what YOUR car is doin when you get the flash!! Well we are going to be working on setting up a dyno day for those that are interested in finding this out. This thread is posted to generate interest in doing this. I will post more info when i get it. This dyno day will be called FLASH DANCE because we believe when you get the flash and see your numbers that coincide with what your butt dyno says then you will be doing the flash dance!!
CPE catless DP// CPE catback//CPE standback// SRI// ETS top mount// megan springs// turbine tech diff mount//carrilo rods//cp pistons bored .20 over//cometic head gasket/ arp head studs// carrilo crank bolts// balance shaft delete// ported turbine housing// 4" surge compressor housing//port polished bowl port 3 angle valve job// porting intake // 3' inlet and intake// custom FMIC// koni yellow adj ft and rr// SU MM//tial external wastegate 38mm// PG manifold//spec 2+ clutch and stock flywheel// previous info current weight 3410lbs// 260hp 284tq// best qtr. 13.2@103// RECORD BEST 60ft 1.71 Co-Owner and head mechanic ![]() ![]()
I'm Down but that also depends upon the date
<span style="font-family:Georgia">06 mazdaspeed6 Sport w Nav --- If it's too good to be true, It's too good for you!!</span> |
I could be down for this also.
"NASCAR is the Bose of auto racing. Makes a lot of money but ain't worth crap" 2006 Black Mica Mazdaspeed 6 Sport 2003 Vibrant Blue Sentra SE-R Spec-V - R.I.P 1/11/07 Auto-X fun |
