Can you say clutch install!!! There will be a clutch install as well as maybe a turbo install if anyone wants or needs something done P3 will be in FULL effect!!! Don't miss it!!
CPE catless DP// CPE catback//CPE standback// SRI// ETS top mount// megan springs// turbine tech diff mount//carrilo rods//cp pistons bored .20 over//cometic head gasket/ arp head studs// carrilo crank bolts// balance shaft delete// ported turbine housing// 4" surge compressor housing//port polished bowl port 3 angle valve job// porting intake // 3' inlet and intake// custom FMIC// koni yellow adj ft and rr// SU MM//tial external wastegate 38mm// PG manifold//spec 2+ clutch and stock flywheel// previous info current weight 3410lbs// 260hp 284tq// best qtr. 13.2@103// RECORD BEST 60ft 1.71 Co-Owner and head mechanic ![]() ![]()
I have some custom exhaust work setup for this weekend, probably sat. It should only take a couple of hours. Beyond that I will be there.
06 Blackcherry Speed6 GT Engine - CP-E CAI, HKS BOV, CP-E FMIC, CP-E catted DP, CP-E Nviscid TIP Drivetrain - CP-E wishbone mount, TT diff mount Suspension - RPM Kspec springs, Koni FSD shocks, SPC adjustable ball joints, Whiteline rear swaybar, Mazdaspeed Rays forged wheels Brakes - Rotora rotors, EBC redstuff, Techna fit SS brake lines, Super blue fluid Electrical - Trunk battery relocation |
ok the new update is that we will be not only installing a GT2871 but a GT3071 as well!!! Man this weekend is going to be busy!!! Parties at P3!!
I'm thinking I'll be there. Just need someone to pm directions or an address to put in the GPS...
Joe 06 Speed6 Platinum Silver CPE CAI, HKS BOV, ETS 3.25" TMIC, CP-E Catted DP, CP-E Dual CB Exhaust, COBB TIP, COBB AP CPE Motor Mount, TWM Stage 1 Short Shifter, COBB shifter weight, MSD Dashhawk RPM Streets, Bilstein HD's, ROTA P-1 Black Wheels, Hawk HPS Brake Pads |
Pm sent!!
ill def be there to witness this as well as installing my manifold! See you guys this weekend!!
2006 MazdaSpeed 6 Grand Touring, Whitewater Pearl Mica - Build Date - 04/2006 Purchased 01/2007 Additional Equipment - Compass/Auto dim Mirror, Black & White Leather, Aluminum Fuel door, Wind Deflector, and MoonRoof. MODS!!! (In Order) <span style="font-family:Century Gothic">\\ 15% Tint All Around \\ CP-E CAI \\ SU Engine Mount \\ <strike>SU Test Pipe</strike> \\ CP-E Catback Exhuast \\ DashHawk \\ <strike>Turbo XS RBV </strike> \\ TWM SS Stage 2 w/ Bushings \\ TWM Desert Eagle Shift Knob \\ RPM Street Springs \\ ProSport Boost Gauge \\ TurboSmart BOV 100% Recirc \\ ETS Top Mount 3.25" \\ CP-E Catted DP \\ <strike>PG Turbo Manifold</strike> \\ BelTronics Sti Radar (HardWired) \\ <strike>NGK One Step Colder Spark Plugs</strike> \\ Denso Iridium Spark Plugs \\ PG CDFP Internals \\ Dekz Vent Pod \\ CP-E SB v2 \\ DNP Manifold \\ SM OCC (2 PCV's) \\ CP-E Turbo Inlet \\ CP-E Tow Plate \\ ACT Performance Clutch Kit \\ L.E.D TailLights\\ TT Front Engine Mount </span> Waiting for my Lazy A$$ to Install - LI Laser Jammer and N2MB Racing Wot Box |
#7 (permalink) |
Booked all day Saturday, was willing to help on the Fourth if the project(s) start then. We should charge admission for the non-P3 dudes...jk.....wait the parking lot already does......muhahahaha.
White Water Pearl MazdaSpeed 6 |
#9 (permalink) |
What day is everyone coming?
#10 (permalink) | |
QUOTE (charles @ Jul 3 2008, 02:28 PM)
