Soo, it appears I have a power steering leak on what I believe is the power steering cooler as per this pic. I guess I would like to know a ball park to get this repaired. Is this a dealer only job? Or can a local garage handle?
From looking around briefly I am seeing parts for that general area, but having a hard time narrowing down exactly what I need. I also came across a power steering cooler kit from Diamond Motorsports, its only 85 bucks, and should be a direct swap as I can tell, is that a worth while upgrade and possibly be a cheaper fix?
It seems to just look like a seal, I cant really check more, lacking tools, equipment etc. I assume this is a fairly common issue, if its a simple job I might be able to persuade some kind folks to lend a wrench.
But for the moment I am flying blind, it drips out of there quite quickly, already filled and emptied the reservoir, going to be a fill up and haul ass job to wherever I choose to get it repaired, just need to know where to start and how much it will likely hurt.
