Trying to work out if its a worthy MOD or not. I am currently running Corksport SRI & TIP, Upgraded HPFP, COBB BCS, Forge Recirc V2, BBR Hybrid Turbo, 2nd cat delete and Versatuner. I will soon be going FMIC & a downpipe is it worth getting the JMF Intake Manifold V1 or is this only rally needed for 400bhp+??
only need it for higher hp really. I'm sure you may gain a bit in flow and certainly in even flow across the runners, but a ported IM is cheaper and probably more efficient for your power levels.
What is involved in porting the IM. In the past i have ported and polished intakes on 2 stroke motor bikes is the principal the same. Basically making the ports as smooth as possible and is it something you could do with a dremel and the correct flapping wheels?
Related Threads
Mazda 6 Forums
2.2M posts
94.6K members
Since 2002
