The longest forged drop in build ever, and it starts like this-
After assisting my #1 piston to part ways with the rod, and destroying the block with no small amount of authority in the process, the time has come to drop a new mill in there.
I don't want to spend a ton of time & $$ on machine shop labor to bring back a used block that might have issues of it's own, so I'm sourcing a virgin long block from MSM. Along with all the tidbits & what-nots listed below, the total price tag should work out to just over $5K by the time she's back on the road again.
The time line is, give or take, get the engine in over the next month, run it on the stock bottom end as the last few loan payments are made and then the credit cards are paid off from this initial spend, then bank the car payment funds till ~2K is put away. That 2K is to forge the bottom end and all the stuff needed to make that happen
So, that should give me an engine with ~15K miles on it, nicely broken in and stable, a perfect home for a drop in forged build. Broken in but not all clapped out & screwed up.
Where am I at now? So far I've orders are placed for:
SCCA membership purchased
when SCCA card shows up I can join MSM & purchase the long block
JBR 80a Trilogy purchased so the shiny newness has a snug & comfy home
CPe Rear diff mount (yes, it's the wrong end of the car, but mounts )
CPe Safe Seals
Luk 10-064 clutch from ebay
Fidenza fw from MAPerformance
I need to pull the injectors and send them off to InjectorRX to be cleaned & tested.
- I'm hoping the #1 injector didn't get trashed, but if it did I'll get a new one and send it with the others so I can be sure they are all flowing evenly.
- I probably will get all new o-rings & such for the injectors since the current set has 75K miles on em.
I need to pick up an engine hoist & stand
I need to PNP my intake mani, then clean it up & probably paint it. Will most likely paint the VC too, but not till the new engine comes in so I can compare the two.
I'm debating if I'm going to do the BSD right away or not. Need to recover the BSD from the old block first.
Fun stuff- At some point I'm going to tear down the old engine. Since #1 went, that means I've got a tired old worn out #3 to look at... I wonder what kind of shape that piston is in, if there are cracked ring lands or how the ring ends look....
New engine break in will most likely mimic phate's process over on MSF- that seems to have generated great results. I'm also going to blackstone the oil & see how the virgin mill evolves.
Lots of pics as stuff arrives and things progress.....
CPe Safe Seals
