Groaned at 15 Times in 9 Posts
Quoted: 17 Post(s)
My port injection setup has been done for a while but in between making another header and changing some things ie, exhaust, intercooler piping I finally got around to doing a little tuning this weekend and all I can say is its good to have plenty of fuel.
Here' my setup Double Pumper DW65c intank pumps 4x FIC 1100cc/min High Impedence Injectors 1x AEM Universal Adjustable Fuel Pressure Regulator 1x Custom Fuel Rail 1x Stock Manifold Pnp/ Modified for PI Replaced all the fuel lines with bio-fuel compatbile fuel line 1x Fuel pump hardwire kit/relay (for second fuel pump) 1x Split Second Additional Injector Controller (will be upgrading to Pro-Efi eventually) Right now I'm running the car on 50/50 e85/gas since my fuel pump internals did not like 100% e85. I still have my meth kit hooked up on the car since I didn't feel like buying a larger intercooler but its only running a D03 nozzle to cool the intake charge. The hta82 is a nasty turbo when its not starving for fuel. I took it out for a spin Saturday morning after some Friday tuning and it annhilated my tranny mount (street unit) which in turn took out my axle, lol. Its all good, I ordered a replacment mount/axle and I'm going to make another mount next weekend. Car puts a big a$$ grin on my face now.
| Sponsored Links | |||
Advertisement | |||
Quoted: 67 Post(s)
Nice! Did you replace the ECU with a standalone? How are you tuning? Post up logs and VD graphs if possible....
2007 mazdaspeed6 GT | titanium gray ![]() COBB AP, intake, TIP | Corksport FMIC | GrimmSpeed 3-port EBCS | KMD HPFP | CP-E inj seals | ATP 3" cat'ed DP | Magnaflow 2.5" CBE | SM OCC w/ check valve | EGR + VTCS delete | TB coolant bypass | JBR IM and TB gaskets | ITV22s | GP-WERKS BSD + oil pan baffle | TT rear diff mount + bushings, front engine mount | BC coilovers | SPC camber adj ball joints | JBR SSP, weighted shift knob. |
#3 (permalink) | |
Quoted: 17 Post(s)
. There's a ALOT of headroom in the PI system b/c right now I have my max duty cycle % set @ 25% @ 5.0 maf volts, but with the increased based fuel pressure I run and the 4cylinder 4 stroke,settings I have on the split second I get more fuel than than the 2/4 cylinder 2 stroke setup the 5th port guys use.
so what kind of dual pump setup you have returnless?
| The Following User Says NO Thank You to Speed6 killah For This Un-useful Post: | cageyvet (02-19-2013) |
Quoted: 17 Post(s)
I never said it was returnless, its just not in plainsight except if you noticed the return line coming off the bottom port of the fpr.
#6 (permalink) | |
Also what kind of dual pump setup you have and how you got the other put to turn on and what size fuel hose. |
#7 (permalink) | |
Quoted: 17 Post(s)
2. I replaced all the fuel line with gates barricade fuel line 3/8" rated at 225psi/bio fuel 3. Used a hardwire kit to kick on one pump and a relay for the other. The only thing I really don't like with this setup is that the my fuel pump internals can't handle the 100% e85 and unless there's a coating thats available that can prevent them from sticking. I'd rather run the port injection off a fuel cell without touching/tapping into the stock fuel system. However, with just the initial results on 50/50 e85 I'd venture to say ill be able to find MBT with just 50/50 e85 but its a pain in the ass going to the gas station and filling up at two separate pumps. |
#9 (permalink) |
how are you mounting the pumps in the tank?
2006 Mazdaspeed 6 GT Black Mica #4126 GT3076R ~ TXS BOV ~ Custom 3" MAF SRI w/ giant AEM filter ~ AP ~ FMIC ~ CPE DP ~ DNP Mani w/Tial 38mm MV-S EWG VTA'd~ CPE BT TIP ~ TWM Stage 1 ~ CPE RMM ~ TTFMM ~ CPE RDM ~ BC CO's slammed ~ SPC BJ's ~ EBC Red's ~ Stoptech's ~ Technafit SS Lines ~ Autometer Boost & STRI EGT ~ 20% Tint ~ LED Tails ~ Denso ITV-24's ~ Xtra Shorty Antenna ~ Dashhawk ~ CPE Dual CBE ~ Whiteline RSB ~ PnP'd IM ~ CDFP Internals ~ labonte meth kit Custom MS6 Short Shifters!!!! |
Advertisement | |
