Quoted: 48 Post(s)
Hey guys, me and my friend have been wanting to race for a while (he has a modded corvette c4), and since were resposible human beings
we decided to take it to the track. So now i need advice on what to upgrade on my speed for a safe track experience (safe for the car i mean ). so far ive got intake, exhasut, tune, and im getting a RMM. What else would i need?
| Sponsored Links | |||
Advertisement | |||
Quoted: 71 Post(s)
I would say: (you may already have)
Rear Diff Mount(s) RSB RMM New brakes/rotors/juice Maybe a tranny mount and PMM (Check the conditions of these) Tranny/diff/PTO/engine/coolant flush with good fluids Any Maintenance over due? (Plugs, DISI valve cleaning) Depending on mileage and wear, suspension I bet a SSP, solid bushing are nice too! I'm sure there is more. Most important are the RSB, Mounts and a good maintenance (fluid, plugs, valve cleaning etc.)
Black Mica 2006 Speed6 GT | 57,000 Miles Cobb AP | Stratified OTS Stage 1 | JBR Stage II Intake - Blue | CP-e Exhaust | CP-e RMM | SURE Shortcut | SURE Return | SURE Anchors | SURE AGS 625g Shift Knob | All Amsoil Fluids | NGK Step 1 Colder | Autotech Internals I'm Registered. Are You? Ms6db.com "I would happily admit to anybody that the Mazdaspeed6 should come with a warning label..." -TiGraySpeed6 |
| The Following User Says Thank You to jm211 For This Useful Post: | evolution99 (01-25-2013) |
#4 (permalink) | |
Quoted: 45 Post(s)
Are you going to the drag strip or like an auto cross type track?
Liquid Platinum 07 Speed 6 #10177JBR 80duro RMM, Sure Juggernaut, Sure Dreadnaught Cobb AP, HTP3.5" Intake, Streetunit TMIC, M2 DP, TurboSmart BOV, Grimmspeed EBCS, AT Internals, GP Werks BSD & Baffle, Denso ITV22, TWM Stage 2, Dashhawk, JBR OCC, JBR TB TIG, SURE IM TIG, VTCS Delete, Clean Valves! ![]() LED tail lights, 20% tint, EVO X rims and VG Sharkfin Soon to be installed: Ford Transit Oil Filter Conversion |
#6 (permalink) | |
Quoted: 71 Post(s)
The anchors under the shifter car are metal but have rubber liners around them. Its a mild improvement and is noticeable when you slam it in gear. There is no more moosh...or give, if you will. Also the SSP (I have the SURE) did help my 2nd gear shift. for autoexing i would get a light weight shift weight or no weight at all. it helps keep it in gear under heavy braking or gassing. Do the Ford Motorcraft tranny fluid. It supposed to be the best.
Black Mica 2006 Speed6 GT | 57,000 Miles Cobb AP | Stratified OTS Stage 1 | JBR Stage II Intake - Blue | CP-e Exhaust | CP-e RMM | SURE Shortcut | SURE Return | SURE Anchors | SURE AGS 625g Shift Knob | All Amsoil Fluids | NGK Step 1 Colder | Autotech Internals I'm Registered. Are You? Ms6db.com "I would happily admit to anybody that the Mazdaspeed6 should come with a warning label..." -TiGraySpeed6 Last edited by jm211; 01-25-2013 at 09:43 PM. |
#7 (permalink) | |
Quoted: 45 Post(s)
The anchors under the shifter car are metal but have rubber liners around them. Its a mild improvement and is noticeable when you slam it in gear. There is no more moosh...or give, if you will. Also the SSP (I have the SURE) did help my 2nd gear shift. for autoexing i would get a light weight shift weight or no weight at all. it helps keep it in gear under heavy braking or gassing.[/QUOTE] I haven't tried the SSP nor lighter shift weight. I've read mixed reviews that with the plate, the linkages/boot need to be greased every few thousand miles which just seems like an added maintenance as well it being ineffective when it comes to shifting into 2nd because it raises the cables up and causes it to bind. I'm not saying it doesn't work, I just don't have the money to experiment with it
#8 (permalink) |
Groaned at 7 Times in 5 Posts
Quoted: 50 Post(s)
Tires... Make sure your tires are in good shape...
![]() "Car is potential for streets. It does cool. Car is potential for do cool on streets." Cobb AP - CP-E Nano SRI - CP-E Single exit CBE - CP-E RMM - PG TIP - SLS TP - Forge V1 BPV - HKS Hipermax LS+ Coilovers - Car_LED Tails - Prosport Gauges - Dashhawk - JBR SSP/Counterweight/Bushings/Heavy Shift Knob
| The Following User Says Thank You to Jjkalai For This Useful Post: | jm211 (01-25-2013) |
#9 (permalink) |
Quoted: 71 Post(s)
DUH! lmao
For what its worth the sure plate keeps the connector low like OEM -- it just moves it to the side. I also just use high temp can lube and spray/clean my linkage every 1000 miles or so. helps as well.
Advertisement | |
