HOW-TO: Cut OEM Springs - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
New User? Register
Old 01-17-2013, 04:18 PM   #11 (permalink)
CanyonRider's Avatar
Quoted: 46 Post(s)
I have no problem with it. Nice work!
I have had cut springs on my Firebird (3/4 of a coil) for years. It will occassionally hit the bump stops on a hard bump, but that may have more to do with the V8 I put in to replace the straight 6.
2003 Mazda 6s MTX
Mods - Yeah, I got some.
My Threads:
DIY Engine Replacement
Track Car Prep
http://www.youtube.com/user/canyonry...ow=grid&view=0
CanyonRider is offline   Reply With Quote
Old 01-17-2013, 04:19 PM   #12 (permalink)
oh_yeams6's Avatar
Groans: 6
Groaned at 4 Times in 4 Posts
Quoted: 128 Post(s)
iTrader: 13 reviews
Originally Posted by IHeartGroceries View Post
Are those my springs?
YOU MURDERER
Damn right they are haha!!
CLEAN YOUR VALVES
oh_yeams6 is offline   Reply With Quote
The Following User Says Thank You to oh_yeams6 For This Useful Post:
IHeartGroceries (01-17-2013)
Old 01-17-2013, 10:10 PM   #13 (permalink)
Groans: 14
Quoted: 21 Post(s)
Long as they are cut properly, both the blade and what you cut off, shouldn't have any issues. Looks good, let us know how she handles!
06 Mazda 6s Grand Sport - stock
89 Mazda RX7 GTUs - sold, :-(
TurboGTU is online now   Reply With Quote
Old 01-17-2013, 10:46 PM   #14 (permalink)
mrl112's Avatar
Quoted: 19 Post(s)
Why'd you get rid of the H&R's if they're so nice? I'm not trying to be a smartass, I'm coming from trucks, so all my information goes in the opposite direction.
-Matt-
(Any pictures I had on here are gone thanks to Webshots going away.)
mrl112 is offline   Reply With Quote
Old 01-17-2013, 10:56 PM   #15 (permalink)
oh_yeams6's Avatar
Groans: 6
Quoted: 128 Post(s)
iTrader: 13 reviews
To change my setup. I have had the H&R springs for a few years now, and I like doing r&t for the platform
CLEAN YOUR VALVES
mrl112 (01-17-2013)
Old 01-17-2013, 11:08 PM   #16 (permalink)
Hixster's Avatar
Quoted: 14 Post(s)
Looks really good! If i had the balls to do it, I definitely would. for now, ill just go off-roading some more.
2006 LPM MS6 Sport -- 108k
COBB AP/SRI || CS TIP || AT Internals || M2 DP || MF CBE
JBR SSP || JBR weighted knob || Centric Blank Rotors
Hawk HPS Pads || PS Boost in Block8Head pod || Kenwood 12
Alpine M500 || XCarLink || CarLED Tails || VG Sharkfin
Hixster is offline   Reply With Quote
The Following User Says Thank You to Hixster For This Useful Post:
oh_yeams6 (01-17-2013)
Old 01-18-2013, 08:51 AM   #17 (permalink)
Quoted: 26 Post(s)
iTrader: 2 reviews
nice work chris, hope you finally found the set up that works for you this time!
question for you, I thought I read somewhere that Forzda also "tighten up" the suspension all around, believe that he was tracking his ride as well and that made the suspension sit a bit lower and added to the drop in ride height. Was curious to ask if you brought this up with him, as from what I can tell from your write up you didn't end up doing this.
Autoexe front grill / Gunmetal RX8 Rims / Forge BPV / H&R / JBR RMM & SSP / ETS TMIC / COBB TIP/SRI / DH / COBB AP / Denso plugs / TT FM / TT RDM / Centric Slotted & Drilled / SS Brake Lines
pending - JBR OCC
bazzarino is offline   Reply With Quote
Old 01-18-2013, 10:58 AM   #18 (permalink)
daztd's Avatar
Groaned at 8 Times in 8 Posts
Quoted: 15 Post(s)
Great job! Nice write up. Thumb's up
2006 MazdaSpeed 6 Grand Touring | Velocity Red Mica
DashHawk, CS TIP/SRI/TMIC, SU MM, JB EGR block plate/plug/TB TIG, CPE RDM, Perrin EBCS, Turbosmart BPV,TWM Stage 2 STS + metal bushings, Denso ITV-22, SM OCC, silicone boost tubes, Bilstein HD, LED bulbs, TRS projectors, HID fogs, Hawks pads, Amsoil diff/pto/trans, navi, XCarLink USB
daztd is offline   Reply With Quote
Old 01-18-2013, 02:23 PM   #19 (permalink)
oh_yeams6's Avatar
Groans: 6
Quoted: 128 Post(s)
iTrader: 13 reviews
FORZDA was referring to the same practice I mentioned in the OP regarding loosening/tightening the bushings after putting the car onto the ground. What he did, however, was take it a step further by loading the car with additonal weight before tightening the bolts up. This essentially is pulling the car downward, but is not something I would recommend unless you were tracking the car like him. It would also put stress on the bushings in the same way as tightening with wheels in the air would. Best is to use the car's weight, then tighten IMO
CLEAN YOUR VALVES
bazzarino (01-18-2013)
Old 01-19-2013, 06:06 PM   #20 (permalink)
Quoted: 46 Post(s)
Yet another advantage of poly bushings is the center sleeve is free to rotate within the bushing - unlike rubber bushings where the center sleeve is bonded to the rubber, creating preload on the control arm.
2003 Mazda 6s MTX
My Threads:
Track Car Prep
The Following User Says Thank You to CanyonRider For This Useful Post:
daztd (01-19-2013)
