Quoted: 48 Post(s)
I dont know if u guys had the sAme problem as me but, every couple of weeks when i pop my hood i notice that my dam cone filter spipped off again. Whether i tighten it a lot or just a bit doent help. Just today it slipped off and jammed between my shifter weight so i couldnt shift into 1,3,5,r. How could i fix this?
| Sponsored Links | |||
Advertisement | |||
Quoted: 33 Post(s)
I'd think there's supposed to be a lip it sits into in the tube, at least mine does. When you tighten the hose clamp it tightens behind it to prevent slip. Is your lip still there?
------------------------------------------------------ 2007 TGM Mazdaspeed6 COBB ACCESSPORT - DENSO ITV22 SPARK PLUGS - COBB SRI - COBB TIH - CUSTOM BORLA CAT-BACK - TWM STAGE 2 SHORT SHIFTER - JBR HEAVYWEIGHT KNOB - TWM SHIFTER BUSHINGS - LED INTERIOR LIGHTS - RPM IPOD CONNECTOR - CHARGESPEED STI LIP - PLASTIDIP'D OEM WHEELS My Speed6 #09241 is registered- How 'bout yours? - ms6db.com |
Quoted: 71 Post(s)
Is it threaded?
I suppose if your missing that part as Dirk suggests you could put a little thread locker on there for the time being. Assuming its threaded in a manner for which my suggestion applies... Then go buy that part and replace when u can!
Black Mica 2006 Speed6 GT | 57,000 Miles Cobb AP | Stratified OTS Stage 1 | JBR Stage II Intake - Blue | CP-e Exhaust | CP-e RMM | SURE Shortcut | SURE Return | SURE Anchors | SURE AGS 625g Shift Knob | All Amsoil Fluids | NGK Step 1 Colder | Autotech Internals I'm Registered. Are You? Ms6db.com "I would happily admit to anybody that the Mazdaspeed6 should come with a warning label..." -TiGraySpeed6 |
Groaned at 8 Times in 7 Posts
Quoted: 177 Post(s)
pictures would help us help you
2006 BCM MS6 GT #00584
CP-E 3" Straight Pipe Exhaust. CP-E TMIC. CS SRI/TIP. SU RMM. SU TP. Forge V1 BPV. Cobb AP. RichTuned. Denso ITV22. PTP HPFP Internals. STi S204 Lip. Megan Racing Springs. GenPu MS3 Wheels. VEI Boost Gauge. Blox Shift Knob. VG Shark Fin. 35W 8000K DDM HID lows/3000k fogs. Super White LED Tag Lights, Parking Lights, Interior Lights. SOLD: 2009 Mazda 6i GT. Comet Gray Mica. 6-speed MT. ![]() |
Groaned at 5 Times in 5 Posts
Quoted: 213 Post(s)
I'm running the same Cobb SRI
Are you still using the original Cobb filter? Not a big deal, lots of folks use different filters, but want a starting point...
Mazdaspeed6 GT #3476 TiGray slicktop Cobb AP, SRI & TIP, BNR S3, MAC 3 Port, FMIC, TS BPV, 3 BAR MAP, VTCS Delete M2 DP & Magnaflow, KMD Internals, GPWerks BSD & Baffle, SM OCC, EGR Delete, SU Billet RMM TWM Stage II STS & JBR SSB, Prosport Mech Boost RX-8 wheels & 235/40 RE760, H&R Sport Springs, SPC abj's, Strapped diff Stage 1 Brakes: Slotted, Hawk’d, Lined & Blued 405/394 AWD - cf1.01 e38 BNRs3 315/372 AWD - cf1.01 e38 k04
Quoted: 48 Post(s)
There is no lip on the maf housing which is where it slips off of. And what do u mean by threaded? Il post a pic as soon as i can
#7 (permalink) |
Quoted: 33 Post(s)
I can take pics of mine tomorrow. It's dark now.
| The Following User Says Thank You to Dirk McGurck For This Useful Post: | evolution99 (01-01-2013) |
#9 (permalink) |
Quoted: 33 Post(s)
Did you drive through a salt factory? Geez. I'll get a pic of mine sans filter shortly.
#10 (permalink) |
Quoted: 33 Post(s)
Okay, no lip, I must have been remembering something else. Now, the inside of the filter is a little rough, the plastics part. The plastic part it attaches to on the tube has a rough texture, too. When the hose clamp is tightened, friction holds it on.
Advertisement | |
