Another Passenger Motor Mount Failure - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
New User? Register
Old 12-08-2012, 12:56 PM   #1 (permalink)
oh_yeams6's Avatar
Groans: 6
Groaned at 4 Times in 4 Posts
Quoted: 128 Post(s)
iTrader: 13 reviews
Default Another Passenger Motor Mount Failure
After my buddy had been having the following symptoms, we swapped out his second OEM PMM today:
  • Creaking over bumps
  • Sloppy shift feel
  • Creaking when cold, no noise when engine gets hot
  • Excess engine movement
Replaced it with Anchor 9182, which is dirt cheap on RockAuto, and has worked well with others. The car now feels amazing, and all the symptoms are gone. These OEM mounts are shit, this one had ~10k miles on it.
Failure video:
Mazdaspeed 6 Passenger Motor Mount Failure - YouTube
CLEAN YOUR VALVES
oh_yeams6 is online now   Reply With Quote
The Following User Says Thank You to oh_yeams6 For This Useful Post:
JDW1 (12-08-2012)
Old 12-08-2012, 01:37 PM   #2 (permalink)
IHeartGroceries's Avatar
Groaned at 6 Times in 6 Posts
Quoted: 65 Post(s)
Yes, they are certainly not built for longevity. They are the same as the MZ6 mount, correct? I wonder if the added weight on the nose of the MS6 causes accelerated wear. Did the car you worked on have aftermarket mounts at the trans or RMM?
I had the original PMM replaced under warranty at like 25K miles; one of the jobs Mike Ernest/Mike Rhea did for me when they were at Town North.
IHeartGroceries is offline   Reply With Quote
Old 12-08-2012, 02:15 PM   #3 (permalink)
IamJamen's Avatar
Quoted: 15 Post(s)
I just ordered one of the Anchor mounts from RockAuto as well. Hopefully that will clean up my sloppy shift feel as it did for your friend's car.
'06 LPM MS6 GT
IamJamen is offline   Reply With Quote
Old 12-08-2012, 02:28 PM   #4 (permalink)
oh_yeams6's Avatar
Groans: 6
Quoted: 128 Post(s)
iTrader: 13 reviews
I believe the 6/ms6 use all the same mounts.
The car had upgraded RMM and a replaced OEM Trans mount
CLEAN YOUR VALVES
Old 12-08-2012, 03:34 PM   #5 (permalink)
jm211's Avatar
Quoted: 71 Post(s)
I'm sure the added stiffness pushed more stress on the weaker mounts too..
Black Mica 2006 Speed6 GT | 57,000 Miles
Cobb AP | Stratified OTS Stage 1 | JBR Stage II Intake - Blue | CP-e Exhaust | CP-e RMM | SURE Shortcut | SURE Return | SURE Anchors | SURE AGS 625g Shift Knob | All Amsoil Fluids | NGK Step 1 Colder | Autotech Internals
I'm Registered. Are You? Ms6db.com
"I would happily admit to anybody that the Mazdaspeed6 should come with a warning label..."
-TiGraySpeed6
jm211 is offline   Reply With Quote
The Following User Says Thank You to jm211 For This Useful Post:
IHeartGroceries (12-08-2012)
Old 12-08-2012, 04:23 PM   #6 (permalink)
Quoted: 65 Post(s)
I belive that may also be the case; Modifying one or more of the other mounts may stress the OE PMM.
Old 12-08-2012, 04:37 PM   #7 (permalink)
oh_yeams6's Avatar
Groans: 6
Quoted: 128 Post(s)
iTrader: 13 reviews
I agree, but the fact remains that these mounts should be for a stronger car - 6 vs ms6
CLEAN YOUR VALVES
Old 12-08-2012, 04:46 PM   #8 (permalink)
Quoted: 65 Post(s)
Is the NVH the same between the OE Mazda PMM and comperable aftermarket substitues, like the one from RA?
Old 12-08-2012, 05:15 PM   #9 (permalink)
oh_yeams6's Avatar
Groans: 6
Quoted: 128 Post(s)
iTrader: 13 reviews
Yepp, it doesn't add any NVH. I can't do the AWR vibs, so I chose this
CLEAN YOUR VALVES
Old 12-08-2012, 06:45 PM   #10 (permalink)
Quoted: 65 Post(s)
Haha!! I understand. Vibration and added noise gets pretty intense with AWR PMM.
