Another Passenger Motor Mount Failure - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
New User? Register
Old 12-08-2012, 09:34 PM   #11 (permalink)
fivefingerdeathpunch's Avatar
Quoted: 29 Post(s)
looks just like the mount i just replaced. so much play and definitely a sunk in post.
let me know how the other mount works! i'm convinced the new oem mount i just put in will fail soon. i didnt want to go awr either due to NVH so i'm hoping there is a better option. especially since i want to get a FMM sooner or later.
2006 White Water Pearl Mazdaspeed6 Grand Touring #5430
BNR S3 currently being tuned
SURE RMM - HTP 3" TIP - SSP BigMAF SRI - GS EBCS - M2 Catless DP - Autotech HPFP Internals - Cobb AP - NGK Iridium 1step colder - Custom 2.5" FMIC w/ TR8 - GHL Resonated Dual Catback Exhaust - TS/SU DP BOV - CAR LED tails -
fivefingerdeathpunch is offline   Reply With Quote
Old 12-08-2012, 09:41 PM   #12 (permalink)
Quoted: 41 Post(s)
I'll be putting in my Anchor PMM from Rockauto in the coming few days. Based on my experiences with aftermarket OEM-spec parts, it is likely just a rebuilt unit you get from Rockauto etc. My Anchor mount looks like it was sloppily put together. There's epoxy all over the place that was obviously brushed on. Egh, we'll see what happens.
2006 Velocity Red Mica MS6 #06475
1994 Probe GT
http://forums.probetalk.com/showthread.php?t=1701300497
prdracing is offline   Reply With Quote
Old 12-08-2012, 11:50 PM   #13 (permalink)
I'm wondering what the sure mounts for pmm and tranny will be like in street grade.
I recently had my pmm replaced under warranty (5000km). So it's oem again. I may be imagining things but I so believe it's failing again. Hopefully SURE releases their mounts soon.
2006-Speed 6-GT-Black Mica #00921
Sure rmm|Sure jugg|Sure dread|Sure Aero|Sure sidewinder|Sure anchors|su interior brace|Cobb ap|itv-22(.25)|Sure shortcut|Sure countershift|Shark fin|Corksport LED kit|JBR EGR delete|Plast dip rear+Front emblem| Prosport boost gauge Blockhead pod|Paper clip clutch bypass|Autotech hpfp|SM occ|ptp injector seals and studs|Sure I.M. + T.B. tig|vht side marker +rear reflector|SPC ball joints|corksport tmic
Next:Sure S6 and test pipe then brakes then suspension
micneill is online now   Reply With Quote
Old 12-09-2012, 12:33 AM   #14 (permalink)
oh_yeams6's Avatar
Groans: 6
Groaned at 4 Times in 4 Posts
Quoted: 128 Post(s)
iTrader: 13 reviews
I've had my Anchor for about 5k miles and going strong. For the price of one OEM we can buy three Anchor's, easy choice given how bad the OEM are
CLEAN YOUR VALVES
oh_yeams6 is offline   Reply With Quote
Old 12-09-2012, 07:42 AM   #15 (permalink)
jm211's Avatar
Quoted: 71 Post(s)
And how easy it is to swap out!
Black Mica 2006 Speed6 GT | 57,000 Miles
Cobb AP | Stratified OTS Stage 1 | JBR Stage II Intake - Blue | CP-e Exhaust | CP-e RMM | SURE Shortcut | SURE Return | SURE Anchors | SURE AGS 625g Shift Knob | All Amsoil Fluids | NGK Step 1 Colder | Autotech Internals
I'm Registered. Are You? Ms6db.com
"I would happily admit to anybody that the Mazdaspeed6 should come with a warning label..."
-TiGraySpeed6
jm211 is offline   Reply With Quote
Old 12-10-2012, 12:51 AM   #16 (permalink)
sixme's Avatar
Send a message via AIM to sixme
Has anybody changed out the stock tranny mount from one from Anchor?
2006 Mazdaspeed6 in BCM
Work Cr kai wheels 18x8.5/235-40-18/H&R Springs/ Cobb SRI/CS TIP/Cp-e TMIC/Racepipe/3inch exhaust/ blox 490 shift knob/20%tint/blacked out tails/ blacked out emblems.
sixme is offline   Reply With Quote
Old 12-10-2012, 09:59 AM   #17 (permalink)
black07's Avatar
Personally I have had no luck with the anchor mounts from RockAuto. The first one I purchased did not have threads deep enough into the mount and upon torqueing it down it turned the mount stud. I added some washers as spacers and was able to torque it down, but consequently the mount was bad less than a month later. The replacement I ordered from RockAuto had the same threading issue so I added the spacers from the get go, but this mount's threads stripped when I torqued it down. Im getting refunded and RockAuto has been very helpful with the situation. I have ordered another mount made by DEA. DEA actually lists a different mount for the speed6 and manual tranny 2.3l(A6495 instead of A6494).
2007 Mazdaspeed 6 Black Mica
Drag DR33s(18x7.5 w/45 os) Sumitomo HTR Z III for summer and Blizzaks for winter on factory wheels, Omori boost gauge, Moog adjustable balljoints and RPM sport springs(-.8 camber fronts, -1 camber rears, 0 toe all around), Cobb MS3 SRI w/AEM dryflow filter, Cobb TIP, AWR RMM, Hypertech programmer, Denso ITV22s, Bilstein shocks, Powerstop Z16 ceramic brake pads, Techna-fit SS brake and clutch lines, JBR short shift, spacers and shift knob
black07 is online now   Reply With Quote
Old 12-10-2012, 11:40 AM   #18 (permalink)
oh_yeams6's Avatar
Groans: 6
Quoted: 128 Post(s)
iTrader: 13 reviews
You are referring the the Anchor TRANSMISSION mount I assume? Myself and others all have had no issues with the Passenger (Anchor 9182) mount...
CLEAN YOUR VALVES
Old 12-10-2012, 01:38 PM   #19 (permalink)
black07's Avatar
Nope. Anchor 9182 passenger mount.
