System too lean at idle, help - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 19 (permalink) Old 11-17-2012, 03:34 PM Thread Starter
Quoted: 6 Post(s)
Hi , I own a mazdaspeed 6 and just last night the check engine light came one , today I check it and it thee this code p2187 , and I was reading that it could be many things , like boost leak , the canister purge valve , any suggestions ? Will greatly appreciated thanks
Sent from my iPhone using AutoGuide.com App
Sannin89 is offline
post #2 of 19 (permalink) Old 11-17-2012, 04:08 PM
Quoted: 10 Post(s)
List your mods? Monitoring devices?
2006-Speed 6-GT-Black Mica #00921 SOLD
Sure rmm|Sure jugg|Sure dread|Sure Aero|Sure sidewinder|Sure anchors|su interior brace|Cobb ap|itv-22(.25)|Sure shortcut|Sure countershift|Shark fin|Corksport LED kit|JBR EGR delete|Plast dip rear+Front emblem| Prosport boost gauge Blockhead pod|Paper clip clutch bypass|Autotech hpfp|SM occ|ptp injector seals and studs|Sure I.M. + T.B. tig|vht side marker +rear reflector|SPC ball joints|corksport tmic
micneill is offline
The Following User Says Thank You to micneill For This Useful Post:
TiGraySpeed6 (11-17-2012)
post #3 of 19 (permalink) Old 11-17-2012, 05:10 PM Thread Starter
Quoted: 6 Post(s)
Just a CAI and a blow off valveSystem too lean at idle, help-imageuploadedbyautoguide1353186594.719022.jpg
Sannin89 is offline
post #4 of 19 (permalink) Old 11-17-2012, 05:19 PM
Lowspeed
TiGraySpeed6's Avatar
Quoted: 604 Post(s)
Groaned at 7 Times in 7 Posts
iTrader: 2 reviews
can't tell for sure in that pic- is that a BOV or a BPV?
If BOV, it's leaking at idle, essentially a big vac leak. Do you have any means of monitoring your fuel trims or AFR's?
Was a Mazdaspeed6 GT #3476 TiGray slicktop
2009 BMW 135i - double the turbos, double the fun!
E82.N54 / Steptronic w/ Alpina B3 flash / Berk Street exhaust / MHD 1+
340 hp / 371tq
TiGraySpeed6 is offline
post #5 of 19 (permalink) Old 11-17-2012, 08:06 PM Thread Starter
Quoted: 6 Post(s)
Nop, no way of monitoring them
Sannin89 is offline
post #6 of 19 (permalink) Old 11-17-2012, 08:09 PM Thread Starter
Quoted: 6 Post(s)
Is a BOV
Sannin89 is offline
post #7 of 19 (permalink) Old 11-17-2012, 09:52 PM
oh_yeams6's Avatar
Quoted: 210 Post(s)
Groans: 6
Groaned at 6 Times in 6 Posts
iTrader: 17 reviews
Remove BOV, replace with proper BPV, and good to go. Or get a tuning device and run BOV
Sold my MS6 10.30.13
oh_yeams6 is offline
The Following User Says Thank You to oh_yeams6 For This Useful Post:
jm211 (11-17-2012)
post #8 of 19 (permalink) Old 11-17-2012, 10:39 PM
jm211's Avatar
Quoted: 211 Post(s)
Groans: 12
Groaned at 4 Times in 3 Posts
agreed with yeams6.
If you run BOV you are spitting out air the system is counting on to run properly. This can be circumvented with the use a tuning device to tell the system the air is not really there.
Why a BOV? Because race car?
Black Mica 2006 Speed6 GT | 60,000 Miles
Cobb AP | Stage 1 | JBR Stage II Intake - Blue | CP-e Exhaust | JBR RMM | SURE Shortcut | SURE Return | SURE Anchors | SURE AGS 625g Shift Knob | All Amsoil Fluids | Forge V1
I'm Registered. Are You?
"I would happily admit to anybody that the Mazdaspeed6 should come with a warning label..."
-TiGraySpeed6
jm211 is offline
post #9 of 19 (permalink) Old 11-18-2012, 12:04 AM Thread Starter
Quoted: 6 Post(s)
The BOV came with the car when I bought it , so I didn't know much about it , but thanks guys I appreciate all you help
Sannin89 is offline
post #10 of 19 (permalink) Old 11-18-2012, 12:04 AM Thread Starter
Quoted: 6 Post(s)
I'll definitely replace the BOV
Sannin89 is offline
