Groans: 6
Groaned at 4 Times in 4 Posts
Quoted: 128 Post(s)
iTrader: 13 reviews
I have a creaking, and I am pretty sure it is a control arm. Warranty replaced my front lower-front, and the creaking is still there, so maybe the rear -front lower arm? I do not see the point of replacing the arm(s) themselves though, since bushings are what is going out, I doubt metal would need replacing. Found all bushings on RockAuto, but Mazda might have them for a fair price too. Workshop manual has instructions for replacing bushings as well...
Here is a picture, to help with any ideas...
CLEAN YOUR VALVES |
| Sponsored Links | |||
Advertisement | |||
Just put some grease up in there, the rubber bushing will love it. They'll swell up and your nosie issue will go away for a bit.
Did you double check to see if it was a bearing?
Snow bank, Y U ALWAYS HIT MAZDURP? |
Groans: 6
Quoted: 128 Post(s)
iTrader: 13 reviews
It is when it's cold only. Going over bumps, turning, leaving from parking...goes away when heated up. I have only tried spraying things with grease, but I need to remove wheel to really see everything well
CLEAN YOUR VALVES |
Yea I just had all that done by my extended warranty , they replaced both control arms the whole assembly including bushings and labor and other suspension stuff and fixed my creaking and weird noises when cold
Sent from my Autoguide iPhone app
2006 Mazdaspeed 6 GT MICA Pearl white #3007 CP-E SRI CP-E TMIC |
Groans: 6
Quoted: 128 Post(s)
iTrader: 13 reviews
Did they do upper arm? Or just lower? I have Mazda 100k preowned, which is just power train
CLEAN YOUR VALVES |
#7 (permalink) |
They did both lower and upper on both sides aswell as the bushings they go bad and start making weird noises
#8 (permalink) |
if you don't mind me asking, how much did it run you?
#9 (permalink) |
50 dollar deductible.
#10 (permalink) |
Groaned at 5 Times in 5 Posts
Quoted: 210 Post(s)
extended warranty FTW!
wow, not words you hear very often around this joint
Mazdaspeed6 GT #3476 TiGray slicktop Cobb AP, SRI & TIP, BNR S3, MAC 3 Port, FMIC, TS BPV, 3 BAR MAP, VTCS Delete M2 DP & Magnaflow, KMD Internals, GPWerks BSD & Baffle, SM OCC, EGR Delete, SU Billet RMM TWM Stage II STS & JBR SSB, Prosport Mech Boost RX-8 wheels & 235/40 RE760, H&R Sport Springs, SPC abj's, Strapped diff Stage 1 Brakes: Slotted, Hawk’d, Lined & Blued 405/394 AWD - cf1.01 e38 BNRs3 315/372 AWD - cf1.01 e38 k04
Advertisement | |
