advice for engine management?? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
New User? Register
Old 02-06-2012, 03:51 PM   #1 (permalink)
johnredding's Avatar
Default advice for engine management??
hey guys if anyone can point me in the right direction im looking to buy something like a dashhawk but those are a rare find now..so im wondering what are some of the best or new devices.
i have found the scangauge2 and the plx ones that connect to your iphone but im not sure if im just overlooking some other really good ones.
any help would be great!!
john
johnredding is offline   Reply With Quote
Old 02-06-2012, 03:56 PM   #2 (permalink)
bova80's Avatar
Groans: 13
Groaned at 5 Times in 5 Posts
buy the cobb ap and you get engine monitoring plus tuning all in one.
bova80 is offline   Reply With Quote
The Following 4 Users Say Thank You to bova80 For This Useful Post:
daztd (02-08-2012), jm211 (02-10-2012), RhoadBlock (02-08-2012), theMazdaratti (02-13-2012)
Old 02-06-2012, 04:05 PM   #3 (permalink)
yes i have heard of the cobb ap but i thought that was more ECU tunning and mapping? im looking for real time boost, knock retard and clearing codes etc...im weary of the cobb device as im scared i might mess something up haha but i suppose i could learn.
Old 02-06-2012, 08:27 PM   #4 (permalink)
bova80's Avatar
Groans: 13
it is a tuning device, but it also has a display so you can see all those real time sensors as well as the ability to read and clear codes. i suggest you go do more research.
Old 02-07-2012, 09:48 PM   #5 (permalink)
issard's Avatar
I use an Aeroforce Interceptor gauge. Displays two parameters at a time, red backlight that matches the dash, and 52 mm. Not nearly as handy as the AP or versatile as the Dashhawk, but checks/clears codes and measures most things you'd want.
2006 LPM Mazdaspeed 6
I'm 21 and drive like a grandpa.
issard is offline   Reply With Quote
Old 02-08-2012, 02:29 AM   #6 (permalink)
hey thanks issard i have seen the aeroforce gauge its really nice. where do u have installed in your car? is it a hard to hook up? i have seen it in the center dash but there is no way id be able to do that myself haha
Old 02-08-2012, 07:31 AM   #7 (permalink)
RhoadBlock's Avatar
I'll chime in and recommend the AP too. It'll cost you a bit more but you can tune it for a bit more HP and land a few more MPGs if you can keep your foot off the throttle too much. All the monitoring you could want, a few fun goodies built in, and tunability that can improve performance/efficiency on even a stock motor. For it's price it really is a damn good package.
WFC #271 sub 3000lb curb wieght & a blown motor. 2.3L Duratec acquired. Bye bye DI.
Sponsors: Soundwaves of Tampa | StreetUnit | Team SSP
RhoadBlock is offline   Reply With Quote
Old 02-08-2012, 08:17 AM   #8 (permalink)
issard's Avatar
It plugs into the OBD. Very easy to install then, and they give you a pretty long wire for placing the gauge. I do have it installed in the center vents, which is a real clean look. Trust me, it's not hard at all, and I think there's even a how-to somewhere. Of course, it will fit into any 52mm gauge pod, so there are several options for mounting. To give you an idea:
Old 02-10-2012, 03:51 AM   #9 (permalink)
@RhoadBlock..def considering getting one now..just need to save up some more money cause they are pricey. my only apprehension is im not extremly mechanically gifted..i know the basics but i guess i mean i dont want to do more harm than good, so is it fool proof?
@issard..ok great thanks for the info..im up in canada so in the winter i need every vent i can get haha..but really cool how its all in one..i suppose i can set it in a seperate gauge pod..any threads on hiding the wires?
noob.
Old 02-10-2012, 08:48 AM   #10 (permalink)
jm211's Avatar
AP
You can use the basic tools such as monitoring but if you ever need to re-tune, tune or adjust something it can do it. For example raise idle if your turbo starts smoking all the way to Eco-modes for fuel consumption to simple add-ons like turbo-backs and intakes.
considering you are looking to spend close to 300 anyways, might as well get the best tool for the job and spend a bit more.
Search here and mazda247, these two sites have the best database for all sorts of how-to's.
jm211 is offline   Reply With Quote
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
