Miss Fire - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 9 (permalink) Old 01-06-2012, 01:44 AM Thread Starter
Unitedpnx's Avatar
Unhappy Miss Fire
Hey all,
So a little while back I got a nasty miss fire in cyl# 3. I believe that's the most common one I've seen on forums/online. So I decided to go over my history with the vehicle to see what might have been the cause. I narrowed it down to the spark plugs. I had these crappy E3 plugs that I believed caused my car to miss fire (since this issue had never occurred before). I swapped them out and got myself some NGK Premium Iridium
Part No. ILTR6A8G. I found this information here so I was certain it would solve my issue. It did, for a bit... Now I was driving today and noticed a little jerk in my 6th gear (only when accelerating with boost). I put my foot to the floor and the car jerked back and forth and my CEL came back on. Now I was pretty frustrated so I said to myself, lets try one more time... magically, no more miss fires? I was down shifting to 3rd, 4th, 5th, expecting to have the same issue...but NOTHING happened! It stopped. It only seemed to have happened in 6th. But then I put my foot the floor in 6th and nothing happened. So I'm sitting here going 190km on the highway saying, WTF?
If any of you guys have any suggestions to what is going on please point me in the right direction.
Otherwise if I can't figure this out for myself I'm off to the dealer...
Thanks!
Unitedpnx is offline
post #2 of 9 (permalink) Old 01-06-2012, 04:19 AM
Dephect's Avatar
DO NOT go WOT untill after 3k rpm in gears 1-4 and you want to wait till about 3.5k in gears 5-6. You shouldn't load up any turbo car like that.
The best thing you could have done is toss out those E3 plugs. They are beyond garbage. The next thing is to make sure you are in a safe rpm range to go WOT, and if not then downshift. This means that if you need to pass someone on the highway, downshift to to the appropriate gear and accelerate. I don't even touch 6th gear unless I'm going 70+ on the highway, or I'm shitting on some M3 on the highway.
'93 Rx7 FD3S- 445rwhp 397rwtq Daily Driver__ SOLD!
'06 MazdaSpeed6 GT Black Mica
Mods:Cobb AP (Stage 2+ 93oct B-tuned), MS CAI, Forge BPV v1, Denso ITV-22's, Whiteline RSB, SURE RMM + Dreadnaught, SURE shifter bushings, SU test pipe, BC coilovers.
Originally Posted by jm211 View Post
OP: Don't feel bad, at least those Mazda techs wont eff up your ride....
Dephect is offline
post #3 of 9 (permalink) Old 01-06-2012, 05:16 AM
piotrekkb's Avatar
Groaned at 2 Times in 1 Post
Send a message via Yahoo to piotrekkb
I got to miss fire
piotrekkb is offline
post #4 of 9 (permalink) Old 01-06-2012, 08:19 AM
bova80's Avatar
Quoted: 28 Post(s)
Groans: 15
Groaned at 5 Times in 5 Posts
probably cause NGK plugs suck to, you should buy denso's. Make sure they are properly gapped at .028 as well.
bova80 is offline
The Following 2 Users Say Thank You to bova80 For This Useful Post:
jracer (01-07-2012), SJP0tato (01-06-2012)
post #5 of 9 (permalink) Old 01-06-2012, 01:09 PM Thread Starter
Unitedpnx's Avatar
Thanks for all your input, this is really helpful stuff!
post #6 of 9 (permalink) Old 01-06-2012, 01:27 PM
Quoted: 70 Post(s)
Groans: 6
denso IVT22 gapped to what bova said... the NGK's suck too...
07' Speed6 Velocity Red Mica
Go Faster: CorkSport SRI/TIP, SU Test Pipe, Autotech Internals, IVT22's, Cobb AP
Anti break stuff: SURE Dreadnaught, TorqR6 RMM
Appearence: STRI DSD Boost Guage/Blockhead 60mm Guage Pod, Snow tire/wheels mod for the effin' snow
scubasteve711 is offline
post #7 of 9 (permalink) Old 01-06-2012, 01:38 PM Thread Starter
Unitedpnx's Avatar
Ya I'm ordering those for sure. I'm tired of loosing performance over such stupidity. They come pre gapped @ .028?
post #8 of 9 (permalink) Old 01-07-2012, 10:30 AM
Lowspeed
TiGraySpeed6's Avatar
Quoted: 605 Post(s)
Groaned at 7 Times in 7 Posts
iTrader: 2 reviews
The denso ITV-22 comes pre-gapped at .028 (check em anyway), and are one step colder than the stock plugs. THe heat range being colder is a good thing if you have mods or even just drive fairly aggressively. The denso's can be had in the factory heat range if you're more of a peaceful daily driver stuck in rush hour traffic more than anything else.
I have tested the E3 plugs in my own speed6, and pulled them out the same day. That fancy tip does not do well in the harsh DISI environment, suffering from horrid blow-out under even slightly aggressive acceleration.
Was a Mazdaspeed6 GT #3476 TiGray slicktop
2009 BMW 135i - double the turbos, double the fun!
E82.N54 / Steptronic w/ Alpina B3 flash / Berk Street exhaust / MHD 1+
340 hp / 371tq
TiGraySpeed6 is offline
priceprince (01-09-2012)
post #9 of 9 (permalink) Old 01-07-2012, 05:43 PM
oh_yeams6's Avatar
Quoted: 210 Post(s)
Groans: 6
Groaned at 6 Times in 6 Posts
iTrader: 17 reviews
I know that having a loose filter will give you a misfire as well.
Sold my MS6 10.30.13
oh_yeams6 is offline
