BNR S3 Acquired - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
New User? Register
Old 11-15-2011, 07:06 PM   #1 (permalink)
JDW1's Avatar
Default BNR S3 Acquired
Got it today fellas, go's on this week along w/a DNP mani. I can already feel the extra hosses.
07 Liquid Plat Silver W/BNR S3, DNP mani, ATP DP, custom 3" to 2.5 w/magnaflows, ETS TMIC, Cobb SRI, PG TIP, Cobb AP, Perrin EBCS, Forge V2, HKS Twin Power Ignition, AWR RMM, SM OCC, KMD Int, H&R springs, SPC's, D&S Rotors, EGR Del, CPE Rear Diff Mount and TT RD Brace. RX8 Wheels, SF Antenna, int LED's and 29% tint for looks.
JDW1 is offline   Reply With Quote
The Following User Says Thank You to JDW1 For This Useful Post:
IHeartGroceries (11-17-2011)
Old 11-15-2011, 08:59 PM   #2 (permalink)
MWSpeed6's Avatar
Cool... be sure to tune wgdc and boost, as it will behave very differently than the stock turbo.
2007 mazdaspeed6 GT | titanium gray
Relevant mods: Magnaflow 2.5" CBE | ATP 3" cat'ed DP | SM OCC | EGR delete | ITV22s | GP-WERKS BSD + oil pan baffle | KMD HPFP | GrimmSpeed EBCS (interrupt) | COBB SRI, TIP, AP (boost tuned stage 2 93 oct) | Corksport 3" TMIC | TT rear diff mount + bushings, front engine mount | AutoExe Lowdown springs | SPC camber adj ball joints | JBR SSP + weighted knob.
MWSpeed6 is offline   Reply With Quote
Old 11-15-2011, 09:09 PM   #3 (permalink)
JDW1's Avatar
I was thinking 1/2 WGD and tune from there per someones helpful instructions and staying 20psi and tapering to 18.5.
Old 11-16-2011, 04:12 AM   #4 (permalink)
tune it or you won't feel a difference.
zenger is offline   Reply With Quote
Old 11-16-2011, 07:05 AM   #5 (permalink)
TiGraySpeed6's Avatar
Groaned at 4 Times in 4 Posts
Nice, oughta be lots of fun! I'm looking forward to a build & tune thread with lots of pics & notes so we can play along
Mazdaspeed6 GT #3476 TiGray slicktop
Cobb AP, SRI & TIP, M2 DP, KMD Internals, TS BPV, VTCS Delete, GPWerks BSD & Baffle, SM OCC, EGR Delete, TB Coolant Bypass, SU Billet RMM / TWM Stage II STS & JBR SSB, DashHawk, Prosport Mech Boost / RX-8 wheels & 225 Conti DW, H&R Sport Springs, SPC Ball joints, Strapped diff / Stage 1 Brakes: Centric slotted, Hawk HPS, SS lines & SuperBlue / Optima RedTop 34R, AuxMod, Sub PreAmp v.1, Kicker SoundGate CORE for Zune
TiGraySpeed6 is offline   Reply With Quote
Old 11-16-2011, 08:58 AM   #6 (permalink)
MWSpeed6's Avatar
I disagree. If he doesn't tune there will be a difference and it could be bad. AFAIK the wastegate is different, the turbo responds differently and I'm pretty sure wastegate duty cycle needs to be re-adjusted.
Old 11-16-2011, 09:00 AM   #7 (permalink)
JDW1's Avatar
I will add notes and share any experience but i dont have a good camera so pics may be scarce. I'll try and take a few though.
Looking at 11.4 AFR's, bumping down timing a tad until i get the boost dialed in and boost target of 20 across the board since it's my DD, Joe said it was ok..
Old 11-16-2011, 09:33 AM   #8 (permalink)
If your following wisdom of Forzda1 you should be golden.
As for the math, folks need to remember that 15 psi on a S3 -vs- 15psi on a K04 are two radically different amounts of air, and the loads and fuel will be changing accordingly. It's a must tune situation.
Old 11-16-2011, 09:43 AM   #9 (permalink)
JDW1's Avatar
Given that, i know it's loads more volume but as long as my MAF has a good cal than i should be ok right? I may do it again to make sure but LTFT's were +/- 4 for the most part. I'm planning on doing a good bit of easy driving and monitoring before i get into it.
Old 11-16-2011, 10:04 AM   #10 (permalink)
Given that your not changing the size of the straw, just how much air your sucking through the straw, you will likely not be to bad on the MAF Cal. That said, I tend to believe any changes to breathing require corrections. I'm still on the K04, so I don't have practical knowledge.
Nevertheless, all you know about tuning is still good, you will just need to follow technique, not specific numbers.
- 0 out the "add boost" part of WG Dynamics, so it can still pull boost, but not add boost. Then you still get the safety, but nothing is "faking" your ability to reach desired targets
- 0 out your WGDC and see what boost levels you get on spring only. It is soooo much safer to build up to target than the other way around.
- Be sure you've increased your load targets, even tho your boost tuning.
- be sure you've upped your HPFP target pressures.
- You're already talking about starting with a safe rich AFR, and leaning it out some after boost is set & behaving, so you're already on that
- Keep an eye on your injector duty cycles.
And a million other details, but this is something to think on. Again, if you default to Joe's tuning skills you ought to be fairly safe. Just be sure you understand what you're changing and ASK if it seems odd. Ask him directly, ask here, doesn't matter, just be responsible for your baby!
JDW1 (11-16-2011)
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
