BNR S3 Acquired - Page 7 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
New User? Register
Old 02-06-2012, 07:31 PM   #61 (permalink)
MWSpeed6's Avatar
He's getting KR, so his AFR will be skewed because KR causes the ECU to richen the mixture. Reducing WGDC won't reduce boost in your case, because your WG spring preload is set high enough that it's out of the EBCS's control. I had suggested reducing the preload on the spring so you can reduce boost until you have no KR, so you can tune the MAF and proper WOT AFR. Then begin to raise boost.
2007 mazdaspeed6 GT | titanium gray
Relevant mods: Magnaflow 2.5" CBE | ATP 3" cat'ed DP | SM OCC | EGR delete | ITV22s | GP-WERKS BSD + oil pan baffle | KMD HPFP | GrimmSpeed EBCS (interrupt) | COBB SRI, TIP, AP (boost tuned stage 2 93 oct) | Corksport 3" TMIC | TT rear diff mount + bushings, front engine mount | AutoExe Lowdown springs | SPC camber adj ball joints | JBR SSP + weighted knob.
MWSpeed6 is offline   Reply With Quote
Old 02-06-2012, 08:46 PM   #62 (permalink)
Groans: 7
fuck, the if its the same difficulty as the downpipe... i can totally do this in a weekend
2007 Black Mica MazdaSpeed6
Originally Posted by kwaigonegin View Post
there's an AWD Mazda 6??
Originally Posted by Msp6cop View Post
that is beyond a crying baby jesus. You made the universe cry in... several dimensions. Fuck.
p057 is offline   Reply With Quote
Old 02-07-2012, 04:50 PM   #63 (permalink)
JDW1's Avatar
Max enrichment is 10.9 and i saw 10.45 in one spot. I have tried to dial in a WOT afr but i def think the KR is affecting it. Its spot on in places then go's crazy. I can get the boost down more and see if that will allow for a clean WOT MAF cal i guess.
07 Liquid Plat Silver W/BNR S3, DNP mani, ATP DP, custom 3" to 2.5 w/magnaflows, ETS TMIC, Cobb SRI, PG TIP, Cobb AP, Perrin EBCS, Forge V2, HKS Twin Power Ignition, AWR RMM, SM OCC, KMD Int, H&R springs, SPC's, D&S Rotors, EGR Del, CPE Rear Diff Mount and TT RD Brace. RX8 Wheels, SF Antenna, int LED's and 29% tint for looks.
JDW1 is offline   Reply With Quote
Old 02-07-2012, 05:08 PM   #64 (permalink)
MWSpeed6's Avatar
Yeah, that's what I've been trying to tell you . Here's a quote from the Mazdaspeed COBB ATR help file (a more credible source):
NOTE: IF ANY REPORTS OF KNOCK RETARD (KR) ARE PRESENT DURING THE PULL, THE ECU WILL INJECT ADDITIONAL FUEL TO HELP PREVENT REPORTS OF KR. The higher the reports of KR, the more fuel (in addition to the fuel dictated in the Fuel OL/WOT Commanded EQ (No Knock) table) the ECU will inject. In order to verify the MAF Calibration is set up properly, you will need to make sure that KR is not reported for the entire pull. This may require that you run a lower than desired boost levels in order to datalog a clean dyno run that has no reports of KR.
The Following User Says Thank You to MWSpeed6 For This Useful Post:
JDW1 (02-07-2012)
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
