Strange rattle - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 9 (permalink) Old 10-20-2010, 09:53 PM Thread Starter
cccpms6's Avatar
Strange rattle
If anyone could help me out I would really appreciate it.
Basically my car is a 2006 ms6 and I've owned it for almost 2 years with no problem. Recently I've noticed a strange rattle on start up for like less than a second. Repeating start-up within a minute does not produce the rattle but anything after around 6 mins would produce a rattle. It seems to be coming from the passenger side of the engine where the timing belt is located. After listening to it my dad and I seem to think it might be tensioner for the belt, or maybe even the chain inside.
We noticed that the chain seemed loose for some reason, I'm not sure if its supposed to be like that or not. This could explain why it rattles a bit on start up.
After looking again we are almost positive its the chain. If anyone has had this happen before please pitch in.
Sorry if this might be a common issue, I've just never heard anyone saying anything about this.
cccpms6 is offline
post #2 of 9 (permalink) Old 10-20-2010, 09:56 PM
I dont have a ms6... but Im going to guess it's vvt pin problem
http://www.finishlineperformance.com...02-08-1896.pdf
Uh-Oh is offline
post #3 of 9 (permalink) Old 10-20-2010, 10:02 PM
IHeartGroceries's Avatar
Quoted: 201 Post(s)
Groaned at 9 Times in 9 Posts
Originally Posted by Uh-Oh View Post
I dont have a ms6... but Im going to guess vvt pin problem
... still in warranty?
Highly likely.
TSB: 01-043/07
MULTI-MODEL - VARIABLE VALVE TIMING NOISE WHEN STARTING ENGINE
APPLICABLE MODEL(S)/VINS
2007 Mazdaspeed3 vehicles with VINs lower than JM1BK******742222 (produced before April 1, 2007)
2006-2007 Mazdaspeed6 vehicles with VINs lower than JM1 GG******109660 (produced before April 1, 2007)
2007 Mazda CX-7 vehicles with VINs lower than JM3ER******166945 (produced before April 1, 2007)
DESCRIPTION
When the engine is started, some vehicles may exhibit a loud ticking noise from the variable valve timing actuator at first start for a couple of seconds. This is caused by the lock pin of the variable valve timing actuator not fully engaging. Heat treatment has now been added around the hole of the variable valve timing rotor lock pin to prevent this from happening.
Customers having this concern should have their vehicle repaired using the following repair procedure.
REPAIR PROCEDURE
1. Verify customer concern.
2. Replace the variable valve timing actuator after the engine cools down. Refer to Workshop Manual section 01-10.
3. Do an engine flush and replace the oil filter with a new one to remove dust and metal particles from the engine.
4. Verify repair.
PART(S) INFORMATION
Part Number: L3K9-12-4X0B
Description: Variable Valve Timing Actuator
Qty.: 1
WARRANTY INFORMATION
NOTE:
This warranty information applies only to verified customer complaints on vehicles eligible for warranty repair. Refer to the Warranty Wizard for warranty term information.
Additional diagnostic time cannot be claimed for this repair.
Warranty Type: A
Symptom Code: 82
Damage Code: 9C
Part Number Main Cause: L3K9-12-4X0B
Quantity: 1
Operation Number / Labor Hours::XXC0YXRX / 3.2 Hrs. (CX-7), 3.3 Hrs. (Mazdaspeed3), 3.6 Hrs. (Mazdaspeed6)
Copyright Mazda North American Operations
If you're under any type of warranty, take her in asap, with TSB literature in hand.
If you're not under warranty, I have seen dealer quotes ranging from $700-$1200 to repair this issue.
2013 Ford Taurus SHO, 402A, Perf Pkg, Livernois Tuned
2013 Mazda CX-5 Touring w/ Tech
2002 Dodge Neon SXT
1972 Chevrolet C-10, 350/350
1967 Buick Skylark 2DR, 300/300
IHeartGroceries is offline
post #4 of 9 (permalink) Old 10-20-2010, 10:02 PM Thread Starter
cccpms6's Avatar
dang it, I've heard of the vvt pin problem but for some reason I thought it was something different.
Thanks man. Everything makes sense now.
cccpms6 is offline
post #5 of 9 (permalink) Old 10-20-2010, 10:05 PM Thread Starter
cccpms6's Avatar
Would it be safe for me to drive the car for sometime though?
EDIT: Basically my girlfriends birthday is this week and I am planning on visiting her. This requires a trip up to MA. So basically its a 500 mile trip one way. I really need to make this trip though. So I'm left with a question would it be safe to do this? Reading through the symptoms and procedure of the TSB it seems like it would not cause any damage. But I need to be sure.
cccpms6 is offline
post #6 of 9 (permalink) Old 10-20-2010, 11:05 PM
daztd's Avatar
Quoted: 35 Post(s)
Groaned at 8 Times in 8 Posts
I had my VVT pin replaced 2.5 yrs ago. Can it go bad again with the new heat treatment one?
2006 MazdaSpeed 6 Grand Touring | Velocity Red Mica
DashHawk, CS TIP/SRI/TMIC, SU MM, JB EGR block plate/plug/TB TIG, CPE RDM, Perrin EBCS, Turbosmart BPV,TWM Stage 2 STS + metal bushings, Denso ITV-22, SM OCC, silicone boost tubes, Bilstein HD, LED bulbs, TRS projectors, HID fogs, Hawks pads, Amsoil diff/pto/trans, navi, XCarLink USB
daztd is offline
post #7 of 9 (permalink) Old 10-20-2010, 11:24 PM Thread Starter
cccpms6's Avatar
I've looked throught the other threads on here about the timing chain tensioner and the vvt pin, I've noticed other people asking if these problems unfixed could cause problems in the near future.
I am sure people don't want to say it won't and than have someone lose their engine, but could someone tell me when they had this problem how long they've let it go till they took it in to get it fixed?
cccpms6 is offline
post #8 of 9 (permalink) Old 10-23-2010, 01:28 AM
SRTMikey's Avatar
My car made the noise when I bought it (used). Didn't know it was anything to worry about so I drove it for about 9 months until I read about the TSB on here and I got mine fixed. Don't know if I'll have troubles down the road though. (crossing my fingers I don't)
SRTMikey is offline
post #9 of 9 (permalink) Old 10-23-2010, 02:37 AM
Quoted: 201 Post(s)
Likely would be fine to make the road trip, but driving it long without fixing it could make problems worse.
It's barrowed time, just like everything else.
2002 Dodge Neon SXT
