Go Back   Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum > Technical / Performance / Model > Mazda6 1st Generation (2002-2008) > Mazdaspeed6
Old 11-20-2009, 10:22 AM   #1 (permalink)
WhiteKnight's Avatar
18" MKWs
Rim Size= 18"x114.3
Offset= +40
Seller says they are off a 2006 Mazda6
=WhiteKnight=
=WhiteKnight=
2006 Mazdaspeed6 GT
Mazdaspeed cold air intake + Zinik 18s + Pirelli PZero Neros
WhiteKnight is offline   Reply With Quote
Old 11-20-2009, 10:28 AM   #2 (permalink)
aviator79's Avatar
width?
but yes im sure they will fit as there no more than 8"
RENT FENDER ROLLER</span>
Old 11-20-2009, 02:47 PM   #3 (permalink)
kiseliok's Avatar
Send a message via AIM to kiseliok
shouldn't be a problem..
kiseliok is offline   Reply With Quote
Old 11-20-2009, 03:41 PM   #4 (permalink)
what tires and suspension set up?
depending on that you might rub.
2007 Mazdaspeed 6
dane145 is offline   Reply With Quote
Old 11-20-2009, 03:52 PM   #5 (permalink)
Thanks, guys. Suspension is stock, and I'm planning on running Blizzaks.
=WhiteKnight=
2006 Mazdaspeed6 GT
Old 11-20-2009, 03:53 PM   #6 (permalink)
Should be fine.
<div class='quotetop'>QUOTE
You obviously don't understand digital. Digital is all ones and zero's. If you have a kink in the cable, because it is made cheaply, then the 0's, being as they are round, can slip around the kink's, but the 1's, having sharp edges, pile up.
No need to look under the hood....
SSinstaller is offline   Reply With Quote
