Go Back   Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum > Technical / Performance / Model > Mazda6 1st Generation (2002-2008) > Mazdaspeed6
Old 11-17-2009, 09:08 PM   #1 (permalink)
the car AC outlet between the passenger and driver no longer works. it was working fine when i was powering my Laptop with a Duracell Amplifier and then after an hour it just stopped working. is this a fuse problem? because i don't know what else to do before i take it into the shop.
ITIongo is offline   Reply With Quote
Old 11-17-2009, 09:58 PM   #2 (permalink)
Arinzeuno's Avatar
QUOTE (ITIongo @ Nov 17 2009, 09:08 PM)
the car AC outlet between the passenger and driver no longer works. it was working fine when i was powering my Laptop with a Duracell Amplifier and then after an hour it just stopped working. is this a fuse problem? because i don't know what else to do before i take it into the shop.[/b]
same issue. Would love a fix
95 Mercedes Benz E 320 Twin Turbo
3.2L inline six with 415rwhp/436rwtq @ 13.2psi.
0-60: 3.82 sec (with sandbags)
0-100: 8.56 sec
1/4 mle: 12.21 @ 120.1 mph.
Top Speed: 171 (so far)
3400 lbs
I rep Michigan. Come see me.
Arinzeuno is offline   Reply With Quote
Old 11-17-2009, 10:18 PM   #3 (permalink)
schudel5's Avatar
Seems like a fuse to me. I had the same issue, but with the one in the armrest and it was the fuse.
2006 Mazdaspeed6 Sport - Velocity Red Mica
2008 Mazda6i Touring - Performance White
Certified Pinball Freak!
schudel5 is offline   Reply With Quote
Old 11-18-2009, 02:26 AM   #4 (permalink)
QUOTE (schudel5 @ Nov 17 2009, 07:18 PM)
Seems like a fuse to me. I had the same issue, but with the one in the armrest and it was the fuse.[/b]
the fuse box by the right headlight?
Old 11-18-2009, 03:05 AM   #5 (permalink)
07sp33d6's Avatar
Send a message via AIM to 07sp33d6
should be a diagram on the underside of the fuse box cover
07sp33d6 is offline   Reply With Quote
Old 11-18-2009, 08:20 AM   #6 (permalink)
that is probably the fuse box under the dash by the dead pedal.
07 Mazdaspeed6 GT
MzdSpd.com
bova80 is offline   Reply With Quote
Old 11-18-2009, 09:48 AM   #7 (permalink)
QUOTE (bova80 @ Nov 18 2009, 05:20 AM)
that is probably the fuse box under the dash by the dead pedal.[/b]
yep it's the fuse labled cigar R under the dashboard. the fuse looked fine but i switched it anyway and it worked. thanks guys.
Old 11-18-2009, 10:02 AM   #8 (permalink)
aviator79's Avatar
AC outlet?
RENT FENDER ROLLER</span>
Old 11-18-2009, 10:10 AM   #9 (permalink)
schudel5's Avatar
QUOTE (aviator79 @ Nov 18 2009, 10:02 AM)
AC outlet?[/b]
Short for "Accessory" maybe? Which is ACC...
Old 11-18-2009, 06:15 PM   #10 (permalink)
j2south's Avatar
Was gonna say... I though it was DC!
2006 MAZDASPEED 6 is no more... :..(
PARTING OUT!!! FOR SALE!!!
SM Stage II OCC ($150)
DashHawk ($225)
j2south is offline   Reply With Quote
