Go Back   Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum > Technical / Performance / Model > Mazda6 1st Generation (2002-2008) > Mazdaspeed6
Old 11-12-2009, 09:02 AM   #1 (permalink)
jracer's Avatar
i am getting a dp finally !!
but am worried about getting my o2 sensors out after 52k ..
i know PB blast the shiz out of them can you use heat also ??
do you think i will have problems ??
2006 mazdza speed 6
Cobb AP /Cobb TIP / Cobb SRI / fmic / stage 2 cobb beta map / forge bov /denzo 1 step colder plugs / magnaflow cat back / ATP down pipe / pg v1 ex. mani / H&R springs / SU lower engine mount / prosport boost gage / vent boost gage pod / Tenzo type M wheels / nitto neo gen's / tint / access i pod controler / redline oil in trans-diff / slotted front rotors w/ Ebc red pads / HD front lip / twm desert eagle shift knob /
jracer is offline   Reply With Quote
Old 11-12-2009, 09:29 AM   #2 (permalink)
jd42's Avatar
QUOTE (jracer815 @ Nov 12 2009, 09:02 AM)
i know PB blast the shiz out of them can you use heat also ??[/b]
I've removed both O2 sensors on my car several times. PB Blaster is definitely key. I suggest starting with the engine hot, and spraying the sensors before starting disassembly to give the penetrant time to work. When you get to the point you are ready to remove the sensors, everything should still be warm, which should help. Also, try to get an O2 sensor socket rather than an open-ended wrench (which is more likely to round over the sensor).
Some more tips of mine: http://forum.mazda6club.com/index.php?show...mp;#entry996948
Old 11-12-2009, 09:37 AM   #3 (permalink)
superskaterxes's Avatar
do it with the DP burning hot and they will come right out
GT3076R BITCHES ~ TXS BOV ~ Custom 3" MAF SRI w/ giant AEM filter ~ AP PROtune'd ~ MBC ~ Custom Side-to-Side FMIC w/Treadstone TR8 Core ~ CPE DP ~ DNP Mani w/Tial 38mm MV-S EWG VTA'd~ CPE BT TIP ~ TWM Stage 1 Short Shifter ~ CPE RMM ~ TTFMM ~ CPE RDM ~ BC CO's slammed ~ SPC BJ's ~ EBC Red's ~ Stoptech's ~ Technafit SS Lines ~ Autometer Boost & STRI EGT in Custom Built Vent Pod ~ 20% Tint ~ LED Tails ~ Denso ITV-24's ~ Xtra Shorty Antenna ~ Dashhawk ~ CPE Dual CBE ~ Custom Strut tower bar ~ Whiteline RSB ~ PnP'd IM ~ CDFP Internals ~ labonte meth kit ~ VC tapped OCC ~ 320WHP/385WTQ ~ 12.9 @ 107 1.8 60' ~ fastest stock turbo trap speed in the USA
superskaterxes is offline   Reply With Quote
Old 11-12-2009, 10:59 AM   #4 (permalink)
a7x813's Avatar
Send a message via AIM to a7x813
did mine with the o2 socket from OEM(got it at Autozone) without the engine being hot. worked like a charm
--AEM CAI--Corksport DownPipe--Forge Motorsports BPV--Denso ITV22--Eibach Pro Springs--Cobb TIP--AWR MM--Corksport Race Pipe--Glowshift Boost Gauge--TWM SS--Redline Quick Lift--Tinted Side Markers--VG Sharkfin--10000k D2S--2700k Fogs--
13.3 @ 99.7
a7x813 is offline   Reply With Quote
Old 11-12-2009, 11:06 AM   #5 (permalink)
I was worried about it too and I f'ed it up... I stripped the sensor and had to have it replaced. Live and learn. What I spent on getting stuff fixed I should have just had a place do it for me. I had 44K miles on my car.
2007 Mazdaspeed6 GT Black Mica - CPE SRI, CPE Inlet, TT L2A Intercooler, HKS BOV, TWM Stage 2 SS, CPE DP, GHL 3" CBE w/ resonator, CPE MM, VEI boost gauge, CPE Tow Plate, Rays 57Fs, CAR_LED Tails, CarPC
Cobb AP - Stage 2+MSCAI 93 v102
mdd5148 is offline   Reply With Quote
Old 11-12-2009, 11:43 AM   #6 (permalink)
jracer's Avatar
ok gunna try getting them out while super hot !! and PB blaster !!.. hope for the best.!!
i have a AP tune now.. do you have to reflash after the installing the DP ?? unhook the dattery and reflash my AP ??
2006 mazdza speed 6
Old 11-12-2009, 11:48 AM   #7 (permalink)
FORZDA 1's Avatar
QUOTE (mdd5148 @ Nov 12 2009, 12:06 PM)
I was worried about it too and I f'ed it up... I stripped the sensor and had to have it replaced. Live and learn. What I spent on getting stuff fixed I should have just had a place do it for me. I had 44K miles on my car.[/b]
The key to removing the OEM O2 sensor is patience. You need to work it out slowly with slow, smooth back-and-forth motions to prevent galling and complete stripping of the threads. Mine was "bound" up and I got it out with only minor damage to the threads. I cleaned the threads up with a file and installed it into the new dp just fine. If you're not a club fist like most dealership goons, you can get it out and reuse it.
`07 Speed6 Sport Titanium Gray w/Cobb TIP/SRI; ETS TMIC; CorkSport CBE & STB & RTB; OEM BPV; ATP DP w/HF cat; OEM turbo; Cobb AP; Perrin EBCS; KMD HPFP; F2 BSDw/baffle; SM Oil CC; Autometer vac/boost & DashHawk; Koni shocks; WL RSB; SPC Adj balljoints; 18x8 SSR wheels; 225/45 Z1 SS Dunlops; SU RearMM & RearStiff-Diff; TT FrontMM; 0-60 in 4.3 and 1/4 mile 12.96 @ 105.6 with ONLY 266awhp/310awtq is ok for now...
Yeah, I really like Mazda... ZOOM! freakin' ZOOOOOM!
FORZDA 1 is offline   Reply With Quote
Old 11-12-2009, 12:56 PM   #8 (permalink)
aviator79's Avatar
Yah, take the upper heat shields off that block the upper one then get the car hot and follow what forzda said. Back and forth if it gets tight is key to prevent it from catching or binding up. If it gets tight spray it and tighten it back down going back and forth to losten it up and keep working it out like that little by little.
RENT FENDER ROLLER</span>
Old 11-12-2009, 01:25 PM   #9 (permalink)
j2south's Avatar
You'll most likely want to reflash to a different map because your air flow will now change. Unless you are already running a stage two. Most instructions will say to remove the battery cable to reset the fuel trims when doing another mod, however if you reflash to a diff map the AP will also reset the fuel trims. I'd say one or the other. Plus you'll get a CEL if you disconnect the O2 sensor if things are on. I use the radio when I'm working on the car, so I always get CEL's from disconnecting shit!
2006 MAZDASPEED 6 is no more... :..(
PARTING OUT!!! FOR SALE!!!
SM Stage II OCC ($150)
DashHawk ($225)
j2south is offline   Reply With Quote
Old 11-12-2009, 02:14 PM   #10 (permalink)
Damn it, why haven't i ever thought about listening to radio while i wrench. Next time for sure!
http://www.youtube.com/watch?v=wsHLbZyA2Uk watch me but DO NOT watch me
07 speed6
-cp-e cai -tp -amsoil everywhere -whiny diff -forge bpv -cobb ap -saikou mitchshuitsou OCC -Speedie6 Inlet -cp-e fmic -denso 1 step colder plugs -water/meth in the trunk -WOTBOX -CS DP -BSD+baffle -diff braced -whiteline RSB -CS TP -CS CBE -rpm sport -spc BJ -GT3071 -TTFMM -DCR Exh Mani waiting to be installed
djuosnteisn is offline   Reply With Quote
