Go Back   Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum > Technical / Performance / Model > Mazda6 1st Generation (2002-2008) > Mazdaspeed6
Old 11-07-2009, 03:10 AM   #1 (permalink)
Hayate's Avatar
I was reading another localized forum and came across a couple of guys that installed this downpipe from Protuninglab. Quote from poster OCD "the piece is basically a Cp-e knockoff with the added feature of a v-band clamp. It was much easier to install than the Cp-e, and everything lined up perfect. The flanges were warped a bit, but the v-band snugged everything down just right. Id say its a good piece for the price."
http://www.protuninglab.com/doma6tu.html
No cat, but you can't get much cheaper than $280.
2007 MS6, Mazdaspeed CAI, Speedie TIP, RPM Sport Springs, Bilsteins, SPC Adj. Ball Joints, Whiteline Rear Sway Bar, AWR Endlinks, Corksport Frt Tower Brace, GT Spec Trailing Braces, CPE prototype MM, TT Frt Diff Mount, CPE Rear Diff Mount, Cobb AP, Dashhawk, Battery Relocate to trunk bracing.
Wheels: Summer: OEM. Winter: Konig Feathers 17x7.5 +45 (17.1 lbs) w/ Yoko Ice Guard IG20 tires, Racing: BBS STI 17 x 8 +53 hub bored to 67.1 (18 lbs) w/ Yokohama Advan A048 235/45ZR17 R tires.
Hayate is offline   Reply With Quote
Old 11-07-2009, 03:24 AM   #2 (permalink)
Risickulous
jmhinkle's Avatar
Groans: 18
That would be an ATP knock-off. It looks like the Ebay one.
Yup, my car is stock.
jmhinkle is offline   Reply With Quote
Old 11-07-2009, 06:10 AM   #3 (permalink)
Road Rage's Avatar
im glad it fits, but even in the pictures it looks like it was made in a cave with rock tools
"When you can leave black marks from the exit of every turn to the braking points of the next turn, then you have enough horsepower."
"Oversteer is when you hit the wall with the back of the car. Understeer is when you hit the wall with the front of the car. Horsepower is how fast you hit the wall. Torque is how far the wall moves after you hit it."
06 Black Cherry Mica Speed6
Road Rage is offline   Reply With Quote
Old 11-07-2009, 07:32 AM   #4 (permalink)
BigBens6's Avatar
Groans: 5
Send a message via AIM to BigBens6
there englishs are very well talked two....
haha
How does it perform, noticable i presume, no performance difference to the CP-E
2006 Ti Grey MS6
Boost Guage Instal
Clutch Adjustment
My Nikon Gallery
I'd rather replace my brakes than my engine, so other than the occasional heel/toe downshift I don't put the stress on the engine of compression braking. It's not a diesel.
"I know right? Engine braking...thats crazy. Holy crap though...can you imagine engine acceleration? Jeezus. I'm glad I don't do that!"
- Crossbow -
BigBens6 is offline   Reply With Quote
Old 11-07-2009, 07:33 AM   #5 (permalink)
haha no it doesn't... just has finger prints all over it b/c of the finish. i wish this was out when i changed my downpipe from stock to CP-e to ATP...
Velocity Red Mica Mazdaspeed 6 (stock) (302awhp 348awtq stock turbo)
http://www.cardomain.com/ride/3355101
Dr. D is offline   Reply With Quote
Old 11-07-2009, 12:27 PM   #6 (permalink)
bmorrisj's Avatar
other than being a knockoff, i havent heard anything bad about the ebay part..... this one is free shipping, may be what i was waiting for...
2007 w/ Cheez
Wheels - MSR 045 18x8 +35
bmorrisj is offline   Reply With Quote
Old 11-08-2009, 03:23 AM   #7 (permalink)
jracer's Avatar
anyone use this ?? whats the verdict.......
2006 mazdza speed 6
Cobb AP /Cobb TIP / Cobb SRI / fmic / stage 2 cobb beta map / forge bov /denzo 1 step colder plugs / magnaflow cat back / ATP down pipe / pg v1 ex. mani / H&R springs / SU lower engine mount / prosport boost gage / vent boost gage pod / Tenzo type M wheels / nitto neo gen's / tint / access i pod controler / redline oil in trans-diff / slotted front rotors w/ Ebc red pads / HD front lip / twm desert eagle shift knob /
jracer is offline   Reply With Quote
Old 11-08-2009, 04:13 PM   #8 (permalink)
Hayate's Avatar
I have a question which I don't think is addressed in other DP posts, but if it please excuse the query...
What are the Pros / Cons of a V-Band clamp pipe (ATP,Protuning) vs a stock type pipe flange (CPE, Corksport) ? Is the clamp liable to fail due to the exhaust heat? I have an idea but am no turbo guru.
Old 11-08-2009, 04:23 PM   #9 (permalink)
Risickulous
jmhinkle's Avatar
Groans: 18
Pro is ease of install. So simple a caveman could do it as the expression goes. There is no downpipe that comes close to it. I'm not sure if there is a con to one. V band definitely won't leak or fail.
Old 11-10-2009, 08:23 AM   #10 (permalink)
jracer's Avatar
has anyone used this downpipe yet ??
2006 mazdza speed 6
