Does anyone know what the maximum backup current is for the speed 6 with full GT trim? The tech manual for a generic 6 is only 20mA. I have a feeling with the Advanced key, ECU, radio and alarm that number should be higher. I test mine at 120mA.
1. Verify that the engine switch is at OFF and that the key has been removed. 2. Disconnect the negative battery cable. 3. Measure the back-up current between the negative battery terminal and the negative battery cable.
2006 Black Cherry Mica Speed 6 GT HKS BPV, Cobb SRI, ATP catless DP, Cobb AP (Stage2+SF 91 v102), Devil's Own Stage 2, Saikou Michi CC, Denso ITV22 |
Its higher, thats why my battery is dead. Killed my goodyear platnum at least 10 times from sitting for months and it finially wont take a charge. Plan to go to sears to get a free new one asap...
RENT FENDER ROLLER</span> CPE Standback - CPE catted DP to dual muffler CS mounts - CPE FMIC w/ OEM air dam & HKS BOV - mrlilguy CDFP - D N <span style="color:#4b0082">P - CPE CAI - speedie6 TIP - SU MM - TWM SS - TT Front MM - TT & CPE Rear Diffmounts - BC Coilovers - Brembo Front/StopTech & EBC Redstuff rear - F2 Baffle <strike>BS</strike> - <strike>VTCS & EGR</strike> - - 8.5x18et45 GM 57F's w/ 245/40 M3s / 18x8.5et45 Advan RZ GM w/ 245/40 Re01Rs - Passport 8500 X50 + LI Quad Laser Jammer - X50 mute button, Sub volume, LI swith & Dashawk custom mounted in steering column - EURO Tails - Rola Roof Rack - Prosport Boost gauge-Vent mount - TSX projector Retrofit - 55w projectors in fog retrofit - Carputer - CRX antenna w/ sat antenna mounted in front - Audison Dynaudio & Alumapro - Amsoil/Schafer Supreme |
#3 (permalink) | |
QUOTE (Sleeper6 @ Sep 23 2009, 01:50 AM)
http://www.westcobattery.com/downloads/accumate.pdf
`07 Speed6 Sport Titanium Gray w/Cobb TIP/SRI; ETS TMIC; CorkSport CBE & STB & RTB; OEM BPV; ATP DP w/HF cat; OEM turbo; Cobb AP; Perrin EBCS; KMD HPFP; F2 BSDw/baffle; SM Oil CC; Autometer vac/boost & DashHawk; Koni shocks; WL RSB; SPC Adj balljoints; 18x8 SSR wheels; 225/45 Z1 SS Dunlops; SU RearMM & RearStiff-Diff; TT FrontMM; 0-60 in 4.3 and 1/4 mile 12.96 @ 105.6 with ONLY 266awhp/310awtq is ok for now... Yeah, I really like Mazda... ZOOM! freakin' ZOOOOOM!
#4 (permalink) | |
QUOTE (FORZDA 1 @ Sep 23 2009, 03:33 PM)
RaceRoots project Mazdaspeed6 in progress! Liquid Platinum Metallic 06 Mazdaspeed6 GT </span> <span style="color:#556B2F">RaceRoots turbo kit/AutoExe Low Down Springs/Mazdaspeed Rays Engineering Forged 18" Wheels/DashHawk/"whoosh" PNP'd IM/PTP IM gasket/VCTS & EGR delete/TB coolant bypass/COBB AP/COBB BOV/COBB shifter weight/TT rear diff mount/TT engine mount/VEI boost gauge/Vent pod/Saikou Michi OCC & ForgeMotorSports hoses/PTP windage tray/F2 BSD/spin on oil filter conversion/RPM AudioLink iPod adapter/808speed6 Bose preamp/RPM smoked rear reflectors/ANZO clear sidemarkers/CX7 antenna/REDLINE MT90 in tranny/80W90 AMSOIL in t-case & rear diff/speed3 oil cap/35% tint/moonroof/CPE dual exhaust/CPE lightweight battery tray/CPE rear diff mount/CPE engine mount Soon to be installed: TWM Stage2 Short Shifter with aftermarket Mazdaspeed shift knob, TWM boot and TWM bushings Toronto (Ski Press)-If you’re driving a nice performance sedan today, say a BMW 3 series, or an Audi A4, and you see a Mazda6 with a lumpy nose pull up alongside, take my advice: don’t make eye contact. Pretend he’s not there. Whatever you do, don’t provoke an impromptu drag race to the next light, ‘cause you’ll get beat like a rented mule. Abused. Whipped. Sayonara, baby. |
#5 (permalink) | |
QUOTE (mpsanger6 @ Sep 23 2009, 05:10 PM)
#6 (permalink) | |
QUOTE (FORZDA 1 @ Sep 24 2009, 01:05 PM)
#7 (permalink) | |
If you are a perfectionist and like to have everything you own work 100%, check out this charger/conditioner: http://www.pulsetech.com/ http://helios.pulsetech.net/cgi/hsrun.exe/...fo?ITNO=100x010 Once in a while, clean the outside of the batt. Road crud gets slightly conductive and slowly drains the charge via short circuit. |
#8 (permalink) | |
QUOTE (HiOfficer @ Sep 24 2009, 08:30 PM)
#9 (permalink) |
I don't drive my car days at a time and my stock battery finally wouldn't hold a charge a couple months ago. I already moved it to the back and didn't think dealer would replace it and I wanted a better one. I don't leave the car off when playing music or anything so I just got a red top 10 year warranty! Lasted about 1.5 weeks without charging with a 180mA draw
(not made to be drained..but that was just a vacation)
MazdaSpeed6 GT 07 Black Mica: 15% Tint - LI + V1 (+20 saves, 1 ticket) - AEM UEGO, STRI Boost/Oil Pressure - Red Top RPM Sport Springs - B/S, EGR Delete, CC - CAR_LED Tails - Smoked Reflectors - TWM SS Stage 2 MrLilGuy's CDFP - ETS 3.25" TMIC+1G DSM BOV - CS DP/RP+ATP VES(Catless) - Cobb AP (Need a tune) FS: TurbineTech Front Motor Mount $250 Shipped PM! WTB: Whiteline RSB adjustable/Meth kit to plug into the stock WW fluid |
#10 (permalink) | |
