Rough Idle/Hesitation/DTC P0300 Set - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 2 (permalink) Old 08-05-2009, 03:31 PM Thread Starter
Does anybody have the full description or PDF version of the below TSB? I'm having these exact symptoms lately:
TSB: 01-002/06
060720 Engine Controls - Rough Idle/Hesitation/DTC P0300 Set
It's not listed in the finishlineperformance.com TSB website.
Thanks!
2006 MAZDASPEED 6 GT Titanium Gray Metallic
Clutch and flywheel replaced under TSB
New Turbo under warranty due to blue smoke issue
All recalls and reflashes
Mobile1 in engine, Redline everywhere else
Kumho Ecsta ASX 225/45/18 UHPAS on stock rims and suspension
20% tint all around - Ticket count: 5
Hardwired BEL960 - Ticket count: 2
muhtarbey is offline
post #2 of 2 (permalink) Old 08-17-2009, 11:26 PM
QUOTE (fenerli @ Aug 5 2009, 02:31 PM)
TSB: 01-002/06
Thanks![/b]
TSB: 01-002/06
ALL MODELS EXCEPT B-SERIES TRUCK & TRIBUTE - ENGINE MISFIRE DIAGNOSTIC PROCEDURES - SERVICE TIP
APPLICABLE MODEL(S)/VINS
2005-2006 MPV 2003-2006 Mazda6 (2.3L), 2005-2006 Mazda6 (3.0L), 2004-2006 Mazda3, 2006 Mazda5, 2004-2006 RX-8, 2006 MX-5, 2006 MAZDASPEED6
DESCRIPTION
Some vehicles may experience rough idle, hesitation, and/or misfire. The concern may occur with the Malfunction Indicator Light (MIL) illuminated and a Diagnostic Trouble Code (DTC) P0300 stored in PCM memory. In other cases, there may be no MIL illumination or DTC stored. Customers having this concern should have their vehicle repaired using the following repair procedure.
REPAIR PROCEDURE NOTE:
- The following repair procedure WILL NOT work on vehicles equipped with a Visteon PCM (i.e.: 2002-2004 MPV and 2003-2004 Mazda6 3.0L)
- Before attempting repairs, be sure the concern can be duplicated at the time of diagnosis.
1. Verify customer concern.
2. Record Freeze Frame Data (FFD).
3. Install WDS to vehicle and I.D. the vehicle.
4. Select the TOOLBOX icon at the top of the screen.
5. Select "POWERTRAIN".
6. Select "OBD TEST MODES".
7. Select "MODE6 ON-BOARD TEST RESULTS", then press the Tick mark.
- Mode06 shows OBD system monitor completion and monitor results. Nearly all OBD monitors work after every drive cycle. However, the results of monitoring stored in memory is only the last / current driving cycle. For misfire monitors, the last ten (10) drive cycles are stored.
- Be sure the PCM has learned the vehicles crank profile before proceeding. A vehicle equipped with misfire monitor needs to learn the crank shaft profile. If Keep Alive Memory is erased, both Mode06 and crank shaft profile data are erased also. In this case, the vehicle must be driven again.
8. Move the scroll bar on the right side of the screen about 3/4 toward the bottom until you see "MISFIRE CYLINDER DATA" for each cylinder.
9. In the "VALUE" column, if a misfire occurred, there will be a number greater than zero (0) shown for that cylinder. The cylinder with a number greater than zero (0) would then be the misfiring cylinder.
NOTE:
- EWMA Exponential Weighted Moving Average. This is an indicator of the average of misfire counts from the last ten (10) driving cycles.
10. If there are all zeroes (0) in the value column for each cylinder, then a misfire did NOT occur in the last 10 drive cycles.
11. Verify repair.
There you go buddy
Fujita CAI, smoke side and rear reflectors, Audio i-pod link connector, And GHL CatBack System with resy, STRI Boost gauge and vent pod
jkspeed06 is offline
