HOW TO FIND A BOOST LEAK - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 133 (permalink) Old 11-01-2008, 10:07 PM Thread Starter
Groans: 6
Okay, here is a great way to test for boost leaks. Very simple, and only costs about 14 bucks, plus it's a tool you can use forever.
So here are the parts you'll need, you can pick them up at your local hardware store in the plumbing department:
You need a 3in to 2in rubber coupler w/ hose clamps. My intake pipe is actually more like 2.75in, but this piece will clamp down sufficiently to seal. You'll also need a 2in pvc pipe plug, this should fit perfectly into the coupler. You'll need like 4ft of 1/4 plastic tube. Lastly, you'll need a threaded 1/4in barb fitting and a 1/4in nut, all still found in the same plumbing section with the brass fittings etc.
Drill out the PVC plug and put the barb threaded end through, and secure with the nut on the other end. I covered all the threads with JBWeld just to be sure it would seal sufficiently.
Put the plug in the 2in end of the coupler.
Hook one end of the 1/4in tubing to the barb, and the other end up to a compressor hose.
Put the other end of coupler onto your intake inlet pipe.
Pressurize the system and listen for leaks.
You can mix up some soap and water if you really need to and smear it around looking for bubbles, but i found it was sufficient to just feel around with my fingers. You can literally feel the air blowing out of the hole if there is one. And DON'T just susupect the couplers, cause it could be a weld, like in my case!
Look at the lil hole in the weld:
It was very surprising how much air flowed out of this dinky hole. I would pressurize the system, and this lil hole would bleed it all off in only a couple seconds.
I'm really trying not to rant in this post, just wanted a "how to", but i had to wait 10 days just for my throttle body coupler while my car was in pieces cause it wasn't shipped with kit ('06s don't need the TB coupler, only '07s, but it was news to me). Then this whole ordeal. Money wasted on a dyno session with depressing results. One night of binge drinking to deal with the depression. And now the leak is in a WELD not a coupler so there is no way i can fix it. Monday i'll be calling cp-e to see what is up. I thought these cores were pressure tested, but guess mine was the exception.
SIGH, MORE TIME WITH MY CAR IN PIECES....
[/rant]
Highest hp stock block ms6
449awhp 527awtq WCF
gt3071, SB + flash combo, self tuned and more on the way...
djuosnteisn is offline
The Following User Says Thank You to djuosnteisn For This Useful Post:
daztd (01-01-2012)
post #2 of 133 (permalink) Old 11-01-2008, 10:29 PM
MS6 P.C.'s Avatar
So you did have a leak? Weld? where?
Edit- nm, found the answer. Great quality control, huh?
gone.
Replaced. Silver speed 6
MS6 P.C. is offline
post #3 of 133 (permalink) Old 11-01-2008, 10:38 PM Thread Starter
Groans: 6
QUOTE (MS6 P.C. @ Nov 1 2008, 05:29 PM)
Edit- nm, found the answer. Great quality control, huh?[/b]
Updated my post with pics of the weld leak. Check op again.
449awhp 527awtq WCF
post #4 of 133 (permalink) Old 11-01-2008, 10:39 PM
bova80's Avatar
Quoted: 28 Post(s)
Groans: 15
Groaned at 5 Times in 5 Posts
you could slap some JB weld over it.
bova80 is offline
post #5 of 133 (permalink) Old 11-02-2008, 01:27 AM Thread Starter
Groans: 6
I could also put a bandaid over my butt hole, but it's not gonna keep me from shitting. LOL. I shouldn't have to jbweld a 1000 dollar intercooler man. I'll get it tig welded by a buddy in a few days.
449awhp 527awtq WCF
post #6 of 133 (permalink) Old 11-02-2008, 01:51 AM
Risickulous
jmhinkle's Avatar
Quoted: 7 Post(s)
Groans: 29
Nice job man. This whole I/C upgrade has been one hell of an ordeal for you huh? You gonna let CP-e know about this?
Yup,
is stock.
jmhinkle is offline
post #7 of 133 (permalink) Old 11-02-2008, 01:00 AM Thread Starter
Groans: 6
honestly, i'm not sure. I'll prob at least call em and tell them about the situation, and maybe give them a few pointers on the mishaps i've had, but i doubt they'll do much for me. When i needed that coupler, i figured they would've sent it over night, but they just sent it ground, and it took a full week to get. full week of having bumper in my living room and parts all over the garage. We'll see, i'm sure they'd appreciate the heads up though.
449awhp 527awtq WCF
post #8 of 133 (permalink) Old 11-02-2008, 08:04 AM
bova80's Avatar
Quoted: 28 Post(s)
Groans: 15
yeah i had to get a weld fixed on my cp-e downpipe because it had a hole in it. they better double check their welds.
bova80 is offline
post #9 of 133 (permalink) Old 11-02-2008, 08:44 AM
This is like daytime tv for gearheads! Glad you found it!
Next week on Speed6 moddin' "Will fixing the boostleak get DJ 300awhp?"
'06 speed6 Liquid Platinum GT w/ Nav
RX8 rims with Toyo Proxes 4 235/40
SU Rear MM, CX-7 shorty antenna
fhaze is offline
post #10 of 133 (permalink) Old 11-02-2008, 11:06 AM
MS6Mike's Avatar
This is a great writeup, I vote sticky!
2006 Velocity Red Mica MS6 GT
Cobb AP*Stage II
CPE Intake / Speedie6 TIP / CPE Motor Mount / CPE 3" Downpipe +cat / PG CDFP Upgrade
RPM Smoked Rear LEDs / RPM Smoked LED Side Markers / MSD Dashhawk / CX7 Antenna
MB Boost wheels + oem Rubber (hot) / oem Wheels + Pirelli Sottozeros (cold)
MS6Mike is offline
