Quoted: 12 Post(s)
i have had plenty are cars, and learned to drive in the pa snow, but last night i was lucky enough to finally bite it, of course it had to be the first car i have ever owned that was newerish
ended up sliding down an icy hill at 2 am, I pulled the ebrake to try to catch the main road at the intersection but ended up across the road and caught a tree stump started repairing today though, ![]() ![]() ![]() im going to try to pull it out, but i imagine i will need to cut out and replace the pillar, and rocker all the way to the wheel well, its not such a big deal because i bought the car totaled in the front end, and was able to fix that. |
| Sponsored Links | |||
Advertisement | |||
Quoted: 14 Post(s)
Is a tough darn car.
Glad you were OK.
Blue Lapis, Tenzo R 18's in Brushed Bronze, Dunlop SP Sports Max TT's 225/40/18, Tein Lowering Springs, Tanabe Sustec Strut Tower Bar & Under Brace, Drilled Slotted Discs, Spectre Intake, MagnaFlow Cat-back Exhaust, DDM HID Kit Slim Ballast 6000K 55W for Hi and Lo Beams, Glowshift Triple Dash Pod and gages, JDM Window Visors, Tint all around, |
Groaned at 7 Times in 7 Posts
Quoted: 183 Post(s)
that sucks man. :[
I lived in virginia beach after moving from pennsylvania my whoile life, when i moved back up i came up with a wife and shes never seen snow and its been two years now and she refuses to drive in snow because she is scared. |
Shiro Shinobi
Quoted: 628 Post(s)
Wow that sucks, glad you're okay though man.
2014 GT, NE Meets, The Great Mazda Climb, and NEW NEM6.com!
![]() TiGraySpeed6: "Back to class youngster, and get off my lawn!" Legacy4Life: "Nothing like a good day of raunchy car talk." 6Y Mazda "One million horsepowerzzz" Sold: 2004 V6 GT |
Quoted: 22 Post(s)
Did you just hold liability insurance on your 6? Glad you are ok, that is always the most important thing. Cars can be replaced or repaired. Looks like it was a pretty hard knock, glad it hit behind your door. Is it still driveable, and if so, how does it drive?
#7 (permalink) |
Groans: 12
Quoted: 257 Post(s)
Has this car been in an accident before? I noticed the facelifted bumper but you have the 03-05 sedan head lights.
#8 (permalink) | |
Quoted: 12 Post(s)
i bought it a few month ago and drove it for a semester of school. the car still drives straight, and like i said im fixing it now, i just need to pull out the pillar, replace the rocker, and get a door. |
#9 (permalink) | |
Quoted: 12 Post(s)
yup still very drivable, im going to temporarily wedge the door back on and drive it, until i can afford a new door. i had compreshive on my car, and glass coverage, because i thought it would help pay for stuff like this, i was told i was at fault, so i dropped comp and glass coverage! |
#10 (permalink) |
Quoted: 194 Post(s)
Ouch!!! That is no walk in the park repair. You need access to a Chief Easyliner with a quad clamps and a couple of hydraulic rams. You will find damage clear to the center of the car and from from each wheel well opening. Its like the strongest part of car to smash and cutting into without pulling it straight first is like the worst idea. You really need to rethink your plan as that car is not going to safe to drive when done.
With quad clamps you grab the drip rail in 4 places under the car. Clamp up the edges of the smashed area and use hydraulic force to pull it out. There several clamps needed and welding to be done. The metal is zinc plated and its High strength, low alloy steel. Heating it softens it and it cracks. That's a serious hit, not to be taken lightly. I used to run one of these for 5 years correcting the "uncorrectable", from DD, to 4X4s, Winston Cup Nascar, exotic sports cars. Get someone with the right equipment to make a couple pulls before you ever try and hack in a part. Its the smart thing to do! Chief EZ Liner S21 Frame Machine | Automotive Equipment | MachineMatch.com Google image some of this: you'll see what the proper clamping system can do. FWIW: it was at least 6000 lbs of force to create that damage. You can bet it will be at least that much to pull it back out! Eckles Auto Body - Whittier Ca body shop serving los angeles and orange county :: Our Facility <<Mazda on the lift! "chief easy-liner" - Google Search
| The Following User Says Thank You to Final Impact For This Useful Post: | Mr.Smoke (01-17-2013) |
Advertisement | |
