Quoted: 12 Post(s)
my 06i 2.3 has terrible heat so far
When first starting i let it warm up for 5-10 min ( its been 30 deg at night ) and my gauge temp just starts to rise. when i begin driving it i have very little hot air, ( and temp gauge is right in the middle ) after 5 minutes of driving i have decent air temp, and not much improvement from there, my hot air is only around 90 deg at full temp i installed a new radiator (because i bought the car wrecked) and did a full flush. i first found my heat wasn't working and flushed my heater core seperate, it was very free flowing, I DONT have much Pressure in my heater core lines, this worries me blend door has been checked, it is working perfect ( mechanical hvac ) im ripping my hair out, and freezing my ass off any suggestions? |
| Sponsored Links | |||
Advertisement | |||
Smoke Screen
![]() Join Date: Dec 2011
Groaned at 4 Times in 4 Posts
Quoted: 682 Post(s)
Simple things first. Have you pressure tested rad cap? Are you sure the cooling system was burped completely?
Sent from my iPhone using Autoguide.com Free App
Quoted: 12 Post(s)
I was very carefull in burping the system, so unless there is a special process for our cars it should be sound, the cap is new, i have a used cap to try, it has push coolant into the overflow for sure
Do we have a water regulator on the heater lines? |
Groans: 42
Quoted: 4 Post(s)
Is the radiator filled properly?
2004 Mazda 6i ATX -Ksport - Magnaflow - Motegi -
Groaned at 6 Times in 1 Post
Quoted: 4 Post(s)
what kind of coolant are you using?
*** ThE FoRk *** |
Quoted: 12 Post(s)
I filled the radiator and burped the shstem out, drove it and burped again, i did this 3 times just to be safe, im running. Peak brand universal green fluid
#7 (permalink) |
Quoted: 4 Post(s)
how did u burp the system?
*** ThE FoRk *** |
#8 (permalink) |
Quoted: 12 Post(s)
i dont have a hvac vacuum, but i burped the system like i would any other vehicle, full heat, get it to temp with cap off, squeeze hoses, check for bubbles, the whole nine yards, keep in mind ive been driving the car for over a month, engine temps are perfect, nothing bad coming up on my scan tool monitors temps wise. i just don't have crap for heater-core flow
#9 (permalink) |
Quoted: 12 Post(s)
changed the thermostat, burped teh system, seems to be hotter, i guess ill find out in the morning though
#10 (permalink) |
Quoted: 7 Post(s)
Check your cab Air filter.
***RIP mazda 6i RIP*** |
Advertisement | |
