Help on Auxiliary jack on 2004 mazda 6 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 12 (permalink) Old 03-19-2013, 10:50 PM Thread Starter
Exclamation Help on Auxiliary jack on 2004 mazda 6
Ive been messing with the thing for around an hour and I cannot make the thing work I used this method to add a headphone port to my car so I can listen to my phone and not have to mess with cds anymore . http://forum.mazda6club.com/electric...se-system.html this is the DIY. The stereo has the same connector but i cannot enable the tape button can anyone help please and thank you
Mazda6101 is offline
post #2 of 12 (permalink) Old 03-19-2013, 10:56 PM
100% CANUCK
Mr.Smoke's Avatar
Quoted: 1305 Post(s)
Groaned at 8 Times in 8 Posts
That DIY is for 06-08 models only. That is stated many many times throught that thread. Your options are the xcarlink, grom & sylflex for AUX in on your car.
Mr.Smoke is offline
The Following User Says Thank You to Mr.Smoke For This Useful Post:
Mazda6101 (03-19-2013)
post #3 of 12 (permalink) Old 03-19-2013, 10:57 PM Thread Starter
ok thank you read it and did not come through that
post #4 of 12 (permalink) Old 03-25-2013, 09:06 PM
addpinto's Avatar
Quoted: 20 Post(s)
Re: Help on Auxiliary jack on 2004 mazda 6
It will work on 03 to 08 .... however in some units you may have to do the L716 mod
2004 Mazda 6i 4dr sedan
addpinto is offline
post #5 of 12 (permalink) Old 03-25-2013, 09:12 PM
100% CANUCK
Mr.Smoke's Avatar
I believe the DIY aux jack has only been made to work on some UK models with the L716 mod.
Mr.Smoke is offline
post #6 of 12 (permalink) Old 03-25-2013, 09:25 PM
addpinto's Avatar
Quoted: 20 Post(s)
Mazda 6 Internal Modification
The factory fitted head unit might require a small modification to the circuit board (the electronic component L716 needs jointing), in order to enable use of the external CD changer port.
HEAD UNIT WHICH DOES NOT RECOGNIZE Media button or the external CD changer port
There are at least two versions of Panasonic(Matsusita) Head Unit on the market. If your Mazda 6 was produced from Nov. 2003 to Sep. 2005, chances are that the Head Unit cannot recognize media button
This is because newer Head Units do not have the zero ohm register on the PCB location L716. To solve this problem, you must take the Head Unit out, open Head Unit (it voids warranty) and solder a Jumper or a 0-ohm chip register on location L716.
Doing this requires soldering skills, if you are not a skilled engineer ask your friend who has skills
https://www.dropbox.com/s/v1rwrnf2js...before%201.gif
https://www.dropbox.com/s/2n8dl9d96j...before%202.jpg
HOW TO PUT JUMPER
1.CHECK YOUR HEAD UNIT FIRST
As described above, this modification is required only for some HUs not all. Before you open HU, try the following steps to test your HU.
a. Connect GROM-I-MAZ to your HU
b. Turn on your HU
c. Play CD as usual
d. Press CD button once again
If the display changes as below and CD play stopped, you DO NOT need the modification.
https://www.dropbox.com/s/j4z1gntixop7jpl/pic%201.gif
If you do not see above display and CD keeps playing, your HU needs modification. Proceed to step 2.
2.TAKE YOUR HU OUT OF MAZDA6
I do not describe here how to remove the HU from the car (sorry I never did it.) Please consult other sources or web site for detailed information.
The first and the hardest part is removing cup holder.
3.OPEN HU
https://www.dropbox.com/s/rjl10sj7xjfat9d/pic%202.gif
4.LOCATE L716
https://www.dropbox.com/s/rbxyyofnss07boy/pic%203.jpg
Bridge L716 soldering pads with thin wire. Be careful not to short other circuits. Left picture above shows L716 open and right picture shows 0ohm chip register soldered.
https://www.dropbox.com/s/zi5kdwuytf3jt6w/pic4.jpg
Put everything back together and enjoy!
addpinto is offline
post #7 of 12 (permalink) Old 03-25-2013, 09:26 PM
addpinto's Avatar
Quoted: 20 Post(s)
I done in 2 mazda 6, 2003 and 2004. Mine was one of them.
addpinto is offline
post #8 of 12 (permalink) Old 04-01-2013, 09:56 AM
Or you could but the syflex auxmod and just be done with it. $60
f4tc0w is offline
post #9 of 12 (permalink) Old 05-14-2016, 03:22 PM
please I leave in philly too. will you do this for me or perhaps give me an extensive "basic language" coaching.
Thanks in advance
phade160 is offline
post #10 of 12 (permalink) Old 05-14-2016, 03:37 PM
Thanks in advance
phade160 is offline
