Double-din Radio Install Kit from EBAY - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
Go Back   Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum > Visual / Audio > Mazda 6 1st Generation (2002-2008)
New User? Register
Old 10-31-2012, 09:19 AM   #1 (permalink)
mv577's Avatar
Default Double-din Radio Install Kit from EBAY
I had posted this in another thread about an entire radio unit on ebay but thought I would post it in it's own thread so it didn't get lost. I know when I was trying to research double-din options there wasn't much out there... so what little info I can offer will hopefully help someone... If you have any questions about something I may have forgot to mention just ask... Here is my original post:
I installed this ebay kit today... http://www.ebay.com/itm/Mazda-6-Radi...item5ae986e0f7
the install isn't complete as I plan to get the 2006 shifter console and cup holder to match the kit... and a few other touch up... this is a quick pic I took when I powered it up today...
https://picasaweb.google.com/lh/phot...eat=directlink
A few notes about the kit...
- It completely disables the information display... other then the back light coming on and off it doesn't show any information...
- All climate controls work as designed, although the buttons aren't as nice as the OEM ones... we'll see how they hold up.
- The climate control lights are a little weak compared to OEM...
- Wiring was straight forward, basically match colors for the radio wires and the shapes of the harnesses to the car... no instructions were provided
- The brackets that hold the radio are plastic but seem to be holding up well...
- It came with a trim ring that fills the small gap around the radio that mounts from the inside of the kit... I ran into an issue with using the ring that it made the radio sit in farther then I liked AND made the holes on the brackets not line up...
- When the brackets were installed on the radio they were wider then where they were meant to mount to the kit... not by much... but enough..
How I fixed those two issues...
I mounted the brackets to the radio and slowly drilled out each mount hole and guide hole until the radio sat in the opening where I like it... I only showed a gap at the top and the bottom of the radio because the brackets filled in the sides... I cut the trim ring they supplied and simply glued it to the kit on the top and bottom of the radio...
Overall I'm 90% satisfied with the kit... I got it for $175 free shipping through the "make an offer" option... and it arrived quickly... There really aren't many options as you all know... so overall I would recommend it if you don't mind loosing your display...
mv577 is offline   Reply With Quote
Old 11-02-2012, 06:51 PM   #2 (permalink)
Tj_Blaire's Avatar
Groaned at 7 Times in 7 Posts
Quoted: 185 Post(s)
I installed this ebay kit today... Mazda 6 Radio Stereo Car Install Double DIN Mount Navigation Bezel Kit Harness | eBay
I got the exact same one for 175 as well and im putting it in this week lol
Tj_Blaire is online now   Reply With Quote
Old 11-04-2012, 10:19 PM   #3 (permalink)
mv577-What year is Mazda 6? thanks
mazdaz62006 is offline   Reply With Quote
Old 11-06-2012, 08:06 PM   #4 (permalink)
mv577's Avatar
2004...
Old 11-06-2012, 08:07 PM   #5 (permalink)
mv577's Avatar
It's growing on me... climate controls still working... nice and solid... would recommend specially since there aren't many options...
Old 11-10-2012, 02:49 AM   #6 (permalink)
Quoted: 33 Post(s)
mine worked just fine and I have 2007 ms6
everything on mine works just like stock
6xer is offline   Reply With Quote
Old 11-12-2012, 12:01 PM   #7 (permalink)
why so expensive? there's no cheaper ways?
EdgarGonzalez17 is offline   Reply With Quote
Old 11-12-2012, 03:55 PM   #8 (permalink)
mv577's Avatar
To clarify... your display works?
Old 11-13-2012, 10:13 AM   #9 (permalink)
it was better to buy in-dash multimedia system, that that mazda kit for screen. something like this: 03-07 MAZDA 6 Navigation system - 7" Digital Touchscreen/ DVD Playback/ USB SD
finkou1 is offline   Reply With Quote
Old 11-13-2012, 11:09 PM   #10 (permalink)
Quoted: 6 Post(s)
iTrader: 2 reviews
Send a message via AIM to mazda6javier Send a message via Yahoo to mazda6javier
got mine today works great
I live my life a quarter mile at a time .
mazda6javier is online now   Reply With Quote
