benner410
Mar 20 2008, 12:03 PM
I have searched for a looooong time now for the perfect set of wheels, and have narrowed it down to 3 choices...
My car is silver w/ sports package, smoked euro tails, clear sides, and soon speed hatch springs. I want to use my 17 inch Dunlops I just bought, so I'm sticking with 17 inch wheels.
A) ASA AR1
17x7
Original Price:
Now 0% Off:
$0 (each)
$130
$130 (each)
Price:
$0 (each)
See price in cart
Offset: 52mm Bolt Pattern: 5-114
Rec. Tire Size: 215/50-17
**Lightweight: 21.0lbs.**
B) Rota Hyper Torque
$650 for all 4
might have to roll fenders
17x7.5
~18 lbs
I think +48 offset
P.S. Thanks silx for letting me use your pics!
C) Kosei KS-T1
ONLY 13.7lbs!!!
17x7
Original Price:
Now 0% Off:
$0 (each)
$179
$179 (each)
Price:
$0 (each)
See price in cart
Offset: 50mm Bolt Pattern: 5-114
**Lightweight: 13.7lbs.**
jmich919
Mar 20 2008, 12:42 PM
I like the Kosei's I was actually thinking of getting them for mine, The second set is nice too though
achow87
Mar 20 2008, 12:53 PM
go with the kosei's. 13.7 is really light and they look decent too.
Poet
Mar 20 2008, 12:55 PM
From what I've read from you so far about wheels, you are more into performance and functionality...So for you, I say the Kosei's...That 13.7lb weight will be awesome.
But I like the way the ASA's look compared to the others.
shotgun salute
Mar 20 2008, 01:57 PM
i would scrap the asa (too much going on in the rim) and go for the performance factor like achow mentioned. 13lbs compared to the 20 some lbs that are stock is going to definitely make a huge difference. overall, whether you may like another set more for the looks, but with the kosei, you will fall more in love with them bc of the difference you will feel. im not saying the difference will be like comparing stewie griffin in size to peter griffin but you will take notice and be glad down the line that you went with the kosei. just my .02
DennisW
Mar 20 2008, 02:34 PM
I'll go against the other comments and suggest the Rota's.
If the tires you have are a larger size than your OEM's, the .5" wider wheel is going to be a help, along with the milder offset in giving you a wider tire footprint as well as a slightly wider track, all good things for handling. Even with stock sized tires the extra width will let them "fill out" a little more.
I"m running 17"x7.5"/48 Rota Subzero's with 225/45x17 Potenza RE-01R's on my 6s and they don't come close to rubbing with a very mild lowering from RB springs, so you should be OK there.
Yes, they're a little heavier than the Kosei's, but lighter than the ASA's.
Just one man's opinion.
Business
Mar 20 2008, 02:51 PM
Torque if only because you have the extra half inch of width. 225's will fit better on that than just a 7" wide wheel.
DennisW
Mar 20 2008, 03:23 PM
QUOTE(Business @ Mar 20 2008, 05:51 PM)
yep....actually a 225 SHOULD be mounted on a 7.5" rim
ZoomZoom999
Mar 20 2008, 03:29 PM
I'd pick the ASAs if looks were more important than weight.
LapisBlueM6S
Mar 20 2008, 04:55 PM
ew asa's.. only bbs can pull that style off, rotas look nice but bootleg jdm's they cant even come up with their own style?????... so yea i voted for #3, great price, light weight... overall nice and good looking too
silx29
Mar 20 2008, 05:15 PM
i vote rotas, not because i had it, but asa= 21lbs?!?!? my 18' zigens are 22lbs.
i didn't know asa's are that heavy
and i think rotas look little better than kosei's on a silver 6, it goes very well with our glacier silver.
and yes 225's fit on 7.5 width. i was using 225/45 on mine.
Poet
Mar 20 2008, 07:01 PM
QUOTE(DennisW @ Mar 20 2008, 05:34 PM)
Yep, the 7in width would be the best reason to NOT go with the Kosei's...So it's kind of a toss up between the 2 of those.
benner410
Mar 20 2008, 08:20 PM
My tires are 215/50.... just sayin', if that makes a difference.
DennisW
Mar 21 2008, 12:15 AM
QUOTE(benner410 @ Mar 20 2008, 11:20 PM)
curious, looking at Rota info I don't see a 7.5" wide rim with the proper bolt pattern for the 6, only the 100mm which won't fit. There is an 8" rim with the 114.3 bolt pattern and a 49mm offset though.
Spidy
Mar 21 2008, 12:27 AM
My vote is for the Torques... you get looks and performance. Its 18lbs which pretty good, and I think the look is more modern. Those Kosei's are lightweight, but honestly, the design looks dated and old school to me...
Sacramento6
Mar 21 2008, 06:26 AM
You will break a 13.7lb wheel that is that cheap at some point by daily driving. Some where in BFE, you'll hit a pot hole and that wheel will leave you stranded. Buy that wheel for track day, get the Rota for everyday.
silx29
Mar 21 2008, 07:04 AM
QUOTE(DennisW @ Mar 21 2008, 01:15 AM)
those rota torques hyperblack are 17x7.5 5x114.3 +45.
blue06mazda6
Mar 21 2008, 11:46 AM
I say the ASA's
The ASA's are also the ones i want to get only in silver.
DennisW
Mar 21 2008, 12:43 PM
QUOTE(silx29 @ Mar 21 2008, 10:04 AM)
If you have a link to somewhere that's marketing them, I'd love to check it out as I'm quite interested in those wheels myself. I tried several different places and every one of them had only a 17x8 in the 114.3 bolt circle, there were 17x7.5's listed but they were all 100mm bolt circles.
xtmesisx
Mar 21 2008, 12:47 PM
one should NEVER buy asa's.
word.
benner410
Mar 21 2008, 09:47 PM
poll is still pretty even... i need more input
Sacramento6
Mar 22 2008, 08:26 AM
You can have cheap.
You can have light.
You can have quality.
You cant have all three. I'll leave it at that. #2 FTW.
TapDatMac
Mar 22 2008, 09:07 AM
Ditch wheel C. I think they would look bad on the car. I like the open spoke design but the kosei's are for rice rockets not Mazda's. Civic=Yes...Mazda=NO!!. Wheels A and B are great and stick with them. Get that car dropped after you get the wheels. Then camber correctly!!!!!!! You should really check out the Helo Tease in black. That is a sick wheel!!! (Helo Tease, Helo 825)
BigBen
Mar 24 2008, 06:23 AM
I voted "B"
Mainly because i have a set in my basement right now...
benner410
Mar 24 2008, 01:19 PM
probably going with choice B so I can get the best of both worlds, but those kosei's are so damn light!
Egierda
Mar 24 2008, 02:04 PM
A = ugly
B = nice but plain
C = track weight rims at one hell of a price; they also are ultra sexy!
benner410
Mar 25 2008, 05:49 PM
TTT
Awong124
Mar 25 2008, 06:38 PM
I don't like any of them.
A - The ASAs, as most people have already said, just plain suck.
B - I don't like the look of the Rotas.
C - Would be the best choice if it wasn't only 7" wide.
If I had to choose between those 3 I'd take the Koseis, but 7" wide is kind of useless, it's the same size as stock.
benner410
Mar 25 2008, 06:39 PM
QUOTE(Awong124 @ Mar 25 2008, 09:38 PM)
Why? for traction?
Awong124
Mar 25 2008, 06:57 PM
QUOTE(benner410 @ Mar 25 2008, 07:39 PM)
Why? for traction?
You won't be able to get wider tires in the future.
IHeartGroceries
Mar 26 2008, 09:28 PM
I have option "C" on my car now, but in 18" X 7.5".
There are quite a few members on this board rolling with these wheels. Hell, I bought mine used from a member.
They are light and they are the best looking out of those options. Are they prone to breaking? I'm sure they are, just as all wheels are. Avoid pot holes and you should be okay. I've had mine on a good while and I've had no problems.
The center caps that come w/ the wheel are puke though, so I roll w/ my rusty hubs exposed.
benner410
Mar 30 2008, 02:48 PM
Even though most of the votes are for the Kosei's, I think I'm going to go with the Rota Torques, simply because they ARE a few pounds lighter than stock, while they also match the color scheme I'm going for.
benner410
Apr 1 2008, 01:27 PM
Nope, changed my mind again.... Goin with the Kosei's.... lol
mazspd6
Apr 2 2008, 07:03 PM
I'm definitely saying Kosei's but my vote will go for the K3 instead, it's a better style for about the same weight but go with a 45 offset at least, but 42 would look best and just give it a roll...mucho hot!!
benner410
Apr 2 2008, 08:39 PM
yea, but it's 17lbs, vs. the k1's 13.7
mariusvt
Apr 3 2008, 07:00 AM
I like the K1 and if you're running a stock tire on them they should have a decent amount of protection from damage.
Toadster
Jul 19 2008, 10:03 PM
DennisW
Jul 19 2008, 10:43 PM
QUOTE (Toadster @ Jul 20 2008, 01:03 AM)
I think I just went blind.
diablo_6
Jul 20 2008, 11:12 PM
QUOTE (TapDatMac @ Mar 22 2008, 01:07 PM)
"kosei's are for rice rockets"??? Wow what an idiot.
Option A? ASA is such a shitty brand its not even funny, its just going to make your car look really cheap.
Koseis are obviously for the tunner look or track use. I don't see why you'd say its for Rice rockets. I'd consider the ASA more as a "Yeah I was to poor to buy nice rims so I just bought black rims with a polished lip"
Also people wondering why the ASA weighs so much....Talk about shit quality.
To the thread maker please don't cheap on your Mazda and actually buy something nice. If I was to pick I'd obviously pick Kosei. I don't even like Rotas to much...Heard bad stuff about em being very weak and Rotas are known for replicas. If anything look into Drag, Advan, Enkei, Tenzo, VOLKS, or OZ wheels. I mean c'mon so much better companies to choose from.
kpjimmy
Jul 21 2008, 05:35 AM
Uhmm "C" for me!
Hostility
Jul 21 2008, 03:07 PM
i can think of about 20 people on these forums that have the koseis.
i like em, but id rather get rotas.
im about to order
THESERota Attack FTW
notenough
Nov 19 2008, 02:36 PM
kosei k1 ts all the way. they weight much less and the quality is good. my brother had them on his last car and was really happy with them.
Mcfly
Nov 19 2008, 02:50 PM
They all look like a PITA to clean, but given a choice between those
three, I'd say..... (B). I feel your pain, it's tough to decide. (A) is too busy.
[C] is too dark in color for me.....Gunmetal looks better on darker cars IMHO.
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please
click here.
