Full Version: Members Wheels
Mazda6 / Atenza > Technical / Performance / Model > Mazda6 1st Generation (2002-2008) > Wheels / Tires
Pages: 1, 2, 3, 4, 5, 6, 7, 8
Mazda Gremlyn
DISCLAIMER: Just because one member did not experience rubbing with a specific wheel/tire combo, that doesn't mean that you won't either. Individual results may vary based on the type of driving you do and your suspension setup.
OK, so the idea here is for everyone that has changed their wheels or tires, etc to post up what they have, include pictures if you like. This way if anyone has questions about what will fit and what won't, they can see what everyone else has done and get ideas.
This is not a thread for discussion, so please post only if you are putting up information. Any posts not strictly on topic for this thread will be deleted. Questions about a member's setup should go through PM to that member. Also please note that if you do not post information with the wheel, the post will be deleted. Include the name/brand, size, and offset.
If you're not sure about one of the specs for the wheel, you can try looking at http://www.wheelspecs.com
I'll start with an example using the stock wheel setups: (info taken from Doc Roadster)
OEM 16in wheels
Tires:
205/60/16 - North America
205/55/16 - Everywhere but North America
Wheels:
Mazda OEM 16x7
+55mm offset
Weight:
21.1lbs
OEM 17in wheels
Tires:
215/50/17 - North America
215/45/17 - Everywhere but North America
Wheels:
Mazda OEM 17x7
+60mm offset
Weight:
21.1lbs
00000
RH C5 Evo
Wheels:
18x7.5
+42mm offset
Tires:
Dunlop W10 215/40/18
springs:
eibach pro kit
fedner:
did not rub at all with eibach, so did not roll the fender
user posted image
DRAGONS6
GramLights 57pros
Wheels:
18x7.5
+52 offset - fit fine w/ no rubbing
Tires:
225/40-18 Toyo T1-R
About 43lbs per corner. I think the rims are about 19.5 lbs each
Eibachs Lowering Springs
I drove pretty hard with them on too. Next time I'll try 225's.
I'll post pics when I get my cam back.
[Here is a picture until you get the ones of your car - MG]
user posted image
ZSilver6
Wheels: Volk GT-U 18 x 7.5 +50 offset
Tires: Pirelli P-Zero Nero 225/40/18
Springs: H&R Sport
No rubbing, no fender roll.
user posted image
user posted image
user posted image
6DereK6
Stock RX-8 wheels
18x8
Tires:
225/45/18
Sprint Lowering Springs
user posted image
critical6
Konig Imagine
Black Opal Finish
19 x 8 +45
Nitto Extreme 225/35
No Drop
No Rubbing
user posted image
Driver6
ASA AR1
Wheels:
18x8
+35mm offset
Tires:
Dunlop SP 9000 225/40/18
springs:
eibach pro kit
fender:
had to be rolled as far as possible, rear wheel wells had to be slightly pulled. No rubbing.
user posted image
user posted image
Michigan6
Motegi MR7
Wheels:
18x7.5
+45mm offset
Tires:
Kuhmo 225/40/18
springs:
Stock
fender:
Have not rolled, and only rubbed once with people in back and going into a steep driveway
redray8
Wheels:
SSR GT7s 18x8
+48 offset
Tires:
Toyo Proxe4 225/40/18
Springs:
Stock
Fenders:
Rolled
user posted image
ATL
Here is mine. 18x7.5 Maxxim Eracer wheels +45 offset with 215/40/18 Yokohama Parada Spec 2 tires. Max grip tires.
user posted image
user posted image
user posted image
user posted image
user posted image
This is with a Eibach drop and no fenders rolled. No problems with rubbing.
Sportsbiz
Enkei RSV
Wheels:
18x7.5
+45mm offset
Anthracite metal finish
Tires:
Falken Ziex 512 215/40/18
springs:
Stock (for now; Eibachs soon!)
fender:
Have not rolled, and has never rubbed. Might change once Eibachs are installed
Kid Cromer
Wheels:
ALT-296 (Blades)
18x7.5
+42mm offset
Tires:
Nitto Neo Gen 215/40/18
Springs:
Eibach Pro-kit
Fender:
Does not rub at all with Eibach. Did not roll the fender.
user posted image
MrTea
Wheels-
Exel TZ-10's
18x7.5
+45 offset
Tires-
Yokohama ES100
225/40ZR18
rubbed badly with eibachs, rolled fenders. no rubbing with almost 2" drop on coilovers
user posted image
user posted image
chubster41
MSR 105
Wheels:
18x7.5
+42mm offset
Tires:
Ventus HRII H405
225/18/40
user posted image
user posted image
user posted image
Does rub only with someone in the back seat or going over a bump at high speeds. Fenders not rolled yet but soon they will be.
GraphiteM6
No longer have them
zoom6i
Just got my wheels on today:
G-Racing Kuma (Hyper Black)
48 18x7.5 Offset 225/40/18
Rubbing: Looks like they will probably rub when I get my lower job done (really close).
Pics soon...
diesel5599
My rims:
Kosei K1 TS 17"s
Offset: +50
My Tires:
Tires: Yokohama AVS dB 2
Rubbing: They do not rub at all, however, the tires to overlap with the rear fender. I think if I put enough weight in the back they would rub, even with the high offset and only 225 width.
Pics:
user posted image
user posted image
user posted image
RazorX
Wheels: ADR M-Sports (Hyperblack) - 18x7.5 +48mm offset
Tires: Michelin Pilot Sport - 225/45/18
Spings: Racing Beat
No Rubbing so far (about 1500 miles on this setup)
ashutoshsm
5Zigen FN01R-C (The lightness - yeah baby!)
17 x 7", 48 offset
Toyo Proxes T1-S
225/45-17
Stock 16" combo with substntially worn tires weighed 46=47 lbs, the new set weighed in at an approximately 10 lbs saving per corner smile.gif
No rubbing including some VERY hard driving wink.gif Not lowered, not that that would matter AT ALL - if its going to rub, it would have!
I've had 2 people in the back and stuff in the trunk - no issues.
user posted image
user posted image
user posted image
And a final closeup ...
user posted image
dalhectar
Falken Torque 5
18x7 +42 Offset
215/40/18 Hankook Ventus Sport K104
Does not rub. No Fender Rool needed
user posted image
user posted image
Car was once fitted with 18x8 +35 offset but those rubbed on rear wheels.
ivan
Work Emotion KAI
18 x 7.5
+42mm
Falken Azenzi Ziex 512's 225/40/18
user posted image
user posted image
bfninjuh
Here are mine:
Motegi DPK's, gunmetal, 19 x 8
+40 offset
225/35/19 toyo proxes 4 wrapped around them bad boys!!!
Eibach's, fenders rolled, no rubbing
[attachmentid=137]
[attachmentid=138]
[attachmentid=139]
[attachmentid=140]
dawei213
Wheel: Arospeed RS-GT 18x7.5 45mm offset
Tires: Falken Ziex 512 225/40-18
Dropped with H&R Springs
No rubbing issue so far, even had 4 stock wheel/tires in the back and cornering hard.
user posted image
user posted image
M6sSG
ENKEI RS6 18*7 38mm
Bridgdestone 225/45/18
Not lowered yet
No rubbing unless full tank or full passenger
QuiQsV6
Even though I have two threads on my wheels I'll post them here too. Cuz they are so purty!! 20.gif
19x8 Graphite(aka Gunmetal) Konig troubles with 45 offset.
Falken Azenis ST-115's 225/35/19
Whoz yo daddy??
user posted image
Full side view
user posted image
Rear angle
user posted image
Front shot
user posted image
Rear wheel top angle shot
user posted image
Front wheel
user posted image
Rear side profile
user posted image
socal714guy
what the hell three spots where my rims are on display!!!!
19 7.5 +45 offset, eibach springs no rubbing, so i didnt roll the fenders
modcraze
ADR M-SPORT GUNMETAL
18X7.5 48+ Offset
Wanli 215/40/18
Eibachs soon to come, no rubbing!!!
<user posted image
koldboi lam
wheels
19'' giovanni racing kobes(kustom painted gloss black)
tires 225/35/19 Falken Azenis St115's
19x7.5 rim
i think 45+ offset
Eibach drop w/ sub in back
user posted image
user posted image
user posted image
NoWeyOut
18 X 7.8 +45 offset
BFGoodrich Scorcher T/A 225/40-18
Stock suspension
Rubbed once, never rubbed again (prolly rubbed fender out of the way ohmy.gif) )
user posted image
http://www.csupomona.edu/~wlnguyen/M6EDIT.jpg
eastside6
Wheels:
Exel hyperblack DL-46 17x7
+45mm offset
Weight: 20 lbs.
Tires:
Falken Ziex 512 215/50/17
Weight: 21.1 lbs.
No rubbing or fender rolling
user posted image
user posted image
critical6
QUOTE(critical6 @ May 2 2004, 01:16 PM)
Konig Imagine
Black Opal Finish
19 x 8 +45
No Drop
No Rubbing
user posted image
[right][snapback]258470[/snapback][/right]
...in my defense (since i dont like people posting about their rims and not posting photos of them on their cars)
user posted image
user posted image
user posted image
SCORPION6
Wheels:
SSR GT1 17x7,5
+48mm offset
Weight: 17,5 lbs.
Tires:
TOYO PROXES T1S 225/45 ZR17 94W
Weight: 20.9 lbs.
Eibach Pro Kit. No rubbing or fender rolling
user posted image
user posted image
user posted image
user posted image
Front with Eibach
user posted image
Rear with Eibach
user posted image
user posted image
user posted image
SCORPION6
Here with the SSR GT1 17x7,5 +48mm offset with the TOYO PROXES T1S 225/45 ZR17 94W
With 400 LBS in the Trunk
user posted image
user posted image
Black2003-6
Here are mine:
Exel TZ-10 17x7 with 45mm offset on 205/50ZR17 Yokohama ES100 Tires with the Eibach 1.5"drop
No Fender roll and no rubbing.
user posted image
Aphextwin
[attachmentid=2150]
Wheels:
G-Racing Siegen 18x7.5
+48mm offset
Tires:
Avon Tech M550 A/S 225/45 WR18 91W
Fenders Rolled
sry110
Wheels: Arospeed RS-GT, 18" x 7.5", +45mm offset
Tires: Pirelli P-Zero Nero M+S
Dropped with H&R springs, fenders rolled.
(Sorry the car's so dirty. Winter just won't stop.)
user posted image
user posted image
anjyl_99
18 x 7.5 Motegi MR7 wheels, 45mm offset, Pirelli 225x40x18 tires, dropped with RB Springs. No rubbing, didn't roll fenders
erak
18" chrome Motegi MR7s
225/40 Federals
Eibach drop
user posted image
user posted image
user posted image
Granada
Enkei Evo5
Toyo Proxes 4 225/45/17
user posted image
user posted image
hieppo
If not already mentioned.
Mazda 6GT (Canadian model) = 6s
No drop
RX-8 wheels with 225/45/18 Dunlop Sport 8090
Normal load with one driver, no rubbing even with everyday driving and a bit of weekend sporty driving.
With about 130kg = 260lbs (2 relatively heavy passengers in the back) load, car would rub with everyday driving and turning corner at very slow speed.
Conclusion, you will need to roll fender. I would be doing that as soon as I can get the tool to do it. There is no question about that since I do carry passengers regularly.
Hope that helps.
Phade2
Wheels:
PIAA 2-Piece Super Rozzas
18 x 7.5 +48
21.5 lbs.
60mm lip
Tires:
225/40 18 Toyo Proxes 4
No rubbing; no fender roll. Will probably roll fenders once I lower it (looks like it has enough clearance once it's dropped so we'll see).
user posted image
user posted image
user posted image
heavyweight
BF Goodrich Tires 215/40/18
18" Chrome MSR's +42 offset
Eibach Pro Lowering Kit
No rubbing
user posted image
sajoka
Enkei RSV 17" X 7"
+42 offset
Toyo T1S 225/45 17
there is a bit of rubbing in the back with people in the backseat. I'm rolling my fenders this weekend. No drop...yet.[attachmentid=2957]
sajoka
One more pic of the Enkei RSV.
[attachmentid=2958]
Hoosteen
Enkei Bortex RPM2 18x8 +45 offset
Hyperblack w/chrome gorilla lugs.
w/ Yokohama Parada Spec II 225/40/18
Rubbed initially
Fenders rolled- no rubbing so far
Car lowered with Tanabe NF's
user posted image
user posted image
gunmetal
Tires:
225/40/18
Wheels:
5ziegen Super Six
18x7.5
48 offset
Springs:
Mazdaspeed
Shocks/Struts:
Koni
rubs a little on outer lip of wheel with weight in back.
Looking for a place to roll the rear.
EDIT : Rolled 36.gif
00000
Velox Hyperion 19x8 45 offset
falken 502 225/35/19
eibach
fender rolled
no rub
user posted image
Zenetti Five 19x8 40 offset
toyo proxes4 225/35/19
eibach
fender rolled completely
no rub
user posted image
ChickenHawk
PIAA FR-S 18 x 7.5 Gunmetal wheels +48 offset
Toyo T1-S 225/40/18 rubber
fenders NOT rolled.. no rubbing at the moment.
[attachmentid=3286]
[attachmentid=3287]
emirem
here is a set of Konig Holes 19x8.5 +48
currently there are NITTO's on it (I rubbed (actually mor like CUT) the hell out of them) .. thinking about getting some Dunlop FM's 225/35-19
user posted image
XxXMaZdAgIrLxXx
Motegi ff7 glossy black with crome lip.
45+mm.
225/40/18 .
Goodyear Essenza tires.
Eibach lowering spring.
Rubbed like crazy. Rolled fender with a rubber hammer(Mallet. I think thats what its called). Worked like a charm.. I also used a heat gun and accidentally burned the rug under one of the wheel wells so now it hits that but no damage to tire. LOL 5.gif
