nj-mazda6
Nov 2 2009, 09:07 PM
My wife isn't all that happy with the ride of her '07 6s - feeling bumps/ruts in the road a little too much. It's also time to replace the summer rated (215/45/18s) with an all season tire. Was thinking about going with a 215/55/18 tire size as an alternative. Will the larger profile improve the ride a bit (ie., more cushion between road and wheel)? Can I go with a 215/50 size instead? Any worries about either of these sizes and rear wheel well (inside) rubbing?
Also not sure if this has been posted before - but here's a nice tire size calculator. Has a look-up feature using Make/Model/Year input for showing the stock tire sizes...
TIRE CALCULATOR
Business
Nov 2 2009, 09:25 PM
Wow, definitely do not go that size.
18" wheels/tires are not known for their comfort level. Going with a 225/50/17 setup would probably do you a LOT better.
jmhinkle
Nov 2 2009, 10:41 PM
Yeah, if you want a softer tire with a larger profile you'll have to go down to a 17" rim.
You could probably find a 15" wire wheel that fits and get some 80 series whitewalls for the ultimate in gangsta comfort. Just sayin.
Awong124
Nov 3 2009, 04:43 PM
The 215/45/18s that came on the car from factory were all seasons, not summers. Unless you got the car used and the previous owner already changed them.
Chris7a6
Nov 10 2009, 07:59 PM
I wouldn't suggest changing the aspect ratio, such as changing the tire to a 215/55/18, if for some reason that doesn't rub, your speedometer would be significantly off. you would only change the height of the tire by about 4 mm but you could get a 225/45/18 and that would give alittle more cushions. Also see what speed rating the tire is, look for lower one such as h and v.. hope this helps
JML
Nov 12 2009, 06:25 AM
Every tire rides a bit differently. You might look into reports of ride comfort from tires that are the same size as what you're now running. For example, I have 17" wheels on my 6, and a set of Michelin Pilot PA3 winter tires rides much more smoothly over bumps and the like, and is far quieter than the OEM all-seasons. The sidewall is probably more flexible.
DennisW
Nov 12 2009, 04:20 PM
QUOTE (nj-mazda6 @ Nov 2 2009, 11:07 PM)
TIRE CALCULATORmore tire sidewall will cushion road shocks better. the 215/50x17's from the earlier Mazda6 regular sedans will give you that slightly softer ride. 55 aspect tires are going to probably be larger in diameter and throw your speedo off a bit more.
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please
click here.
