Full Version: Nitrogen in tires?
Mazda6 / Atenza > Technical / Performance / Model > Mazda6 1st Generation (2002-2008) > Wheels / Tires
QuickSilver6
Does anyone know if nitrogen in tires causes a different feel, is handling affected? Do the tires corner the same?
The reason i ask, i recently purchased new tires, same tires as i had before, i noticed that while driving on the freeway i get a floating feeling, now i know my struts were bad so i put new factory struts on the front, but i still get the same feeling. The only thing i did different between this set of tires is use nitrogen.
posttosh
QUOTE (QuickSilver6 @ May 13 2009, 06:27 PM) *
Atmospheric air is just under four-fifths nitrogen. Almost all of the remaining fifth of air is oxygen, which has similar pneumatic characteristics to nitrogen.
There are arguments to be made for nitrogen fill, but you would have to be uber-sensitive to notice any difference in handling.
QuickSilver6
QUOTE (posttosh @ May 13 2009, 08:06 PM) *
Yeah i just got done reading a huge article on nitrogen in tires, not really worth it.
Sacramento6
^Understatement.
ydrone
I fill mine with 78% nitrogen, and it's fine.
I have access to 100% nitrogen, but I can't figure out how to properly fill up the tires with it, since I can't drain all the air out of the tire all at once.
Sacramento6
To properly do it, a wheel needs two vavle stems. One to fill and one to purge as you fill.
IHeartGroceries
QUOTE (Sacramento6 @ May 15 2009, 12:28 AM) *
Which, I had no idea why my wheels had two stems until about 3-4 months ago.
HenryK
Nitrogen filled tires, only a few dollars extra. What a bunch of marketing Horse Manure. Please, no one realy falls for this, do they?
posttosh
QUOTE (HenryK @ May 18 2009, 05:30 PM) *
Some one fell for it.
Sacramento6
I treated my lawn with nitrogen last month and it looks really lush and green. Probably a better use for the stuff.
priceprince
When I got my new tires, they asked if I wanted nitrogen fill for no extra charge, so I said sure why not. I honestly can't tell much of a difference. The car rides smoother, but I think that is just the new tires talking.
The_Dude
Hate to be the one to ask, and i've searched around for an answer with no luck, but, my Mazda6 came with nitrogen in the tires. Can I add just regular air to them when needed?
gismither
QUOTE (The_Dude @ Jul 27 2009, 10:09 PM) *
Yes
mmonnin
The air you breath is 80% Nitrogen (N2) to begin with. It makes no difference. Its a gimmick.
Falcon1772
Nitrogen is awesome here in alaska for the cold temps. it keeps your pressure from changing with extreme temps.
posttosh
QUOTE (Falcon1772 @ Aug 27 2009, 10:48 AM) *
Down here in the Lower 48, our oxygen (which comprises about a fifth of the air in our tires) behaves, so far as expansion and contraction as a function of temperature is concerned, very much like our nitrogen (which comprises almost four-fifths of the air in our tires). Is Alaskan nitrogen that different from Lower 48 nitrogen, or is it the oxygen up there that is different?
mmonnin
QUOTE (posttosh @ Aug 28 2009, 08:36 AM) *
Haha
Falcon1772
QUOTE (posttosh @ Aug 28 2009, 04:36 AM) *
pretty sure it doesn't get anywhere near -65 down there. but nice try, its good for when you are out and driving then come home and put your car in the garage. Nitrogen doesn't expand and compress like oxygen, sounds like your not as smart as you thought you were. if you fill it to 45psi outside at -45 and then park it in the garage the air expands, then you now have more air pressure in your tire which is a problem. now you have to let some out because you drive outside and now the air in the tires is warm, then it cools down, now you low pressure.
They also use nitrogen in Paintball because it doesn't get weaker with temp, or when it gets low. it keeps pressurized.
I win.
jd42
QUOTE (Falcon1772 @ Aug 29 2009, 12:41 PM) *
Why doesn't nitrogen expand and contract with temperature? Don't all gases follow (or at least approximate) the ideal gas law:
PV = nRT
smoker6
Nitrogen is magical. If you question that there is no hope for you. I have inflated my car seats with nitrogen, and Xzibit heard I like nitrogen, so he put nitrogen in my nitrogen so I can zoom zoom while I zoom zoom boom.
mmonnin
Air is 80% Nitrogen anyway so there is little benefit to using nitrogen filled anything especially when you fill up with low humidity. What is going to expand/contract with temps is the water in the air, not the N2/O2/CO2.
Mcfly
Well, with Nitrogen filled tires, you can say "I don't have ANY 'Air' in my tires",
and not be lying....whoop ti doooo.
Falcon1772
QUOTE (jd42 @ Aug 29 2009, 10:05 AM) *
PV = nRT
no no it does expand and compress, just not with as much variation as oxygen.
Flame6
The biggest bonus is you don't get all the moisture from an air compressor that hasn't been drained in a month. Nitrogen's volume changes with tempurature just like any other gas.
Falcon1772
oh well I guess I don't know then. all I know is it works great at negative temps and regular air doesn't.
with air in my tires my car gets flat spots if left outside. with nitrogen it doesn't, because its not losing any pressure but oh well. Whatever. lol so with that I will leave this post.
Omni
QUOTE (Falcon1772 @ Aug 29 2009, 10:41 AM) *
I win.
Propane is also used in Paintball and Airsoft guns. Everyone should fill their tires with propane then, since its way better than nitrogen. It actually gives you an extra 25hp, just like if you put a "JDM" or "Type R" sticker on your car.
No offense, but if any amount of pressurized gas in a canister 'gets low'...how exactly does it stay pressurized more than any other molecule? o.O Where I came from, if you have a 50psi bottle of nitrogen, and a 50psi bottle of oxygen, and you release enough to reduce it 30psi, there is still 20psi left...no matter what gas is in there.
I can't disprove how nitrogen acts with high or low temp extremes, but I'm going to put propane in my tires tonight, because nitrogen stays pressurized and propane is also used in paintball. who's with me?!!?
