As you know i have the "bolt on" GT2871R turbo on my car. The first time i installed it we cut up the stock oil drain line and used the flanges and some thick fuel line / gator clamps to fabricate one. Had no issues with leaking with it. I recently took off my turbo to have the internal wastegate ported which btw worked out great. We reused the gaskets and tightened the gator clamps but now i am leaking a fair amount of oil from where the oil drain line connects to the turbo I cant really see down there but i stick my hand under there and its obvious thats where it coming from. Im fairly confident its coming from the flange -> turbo connection and not the where the flange connects to the fuel line but i cannot be certain until i remove it.
. I will be getting new gaskets on tuesday to put on and hopefully that will solve the issue.
I had a few questions though. Do the ATP kits made for the MS6 come with the -10 AN oil drain lines similar to the ones use for the MS3 or do they just have you reuse the old one? Is there a better way to fabricate an oil drain line or have one made?
Note: the MS3 -10 AN drain line that ATP supplies with the MS3 "bolt on kit" doesnt work because it gets severly kinked several times when you use it on the speed6 due to transfer case being in the way.
