QUOTE (vnmazda6i @ Jul 30 2008, 10:43 AM)
uhmm..i took that information from the sticky on this forum stating the possible tire size for the 18" ms6 rim. whao i almost got the 225 one..are you really sure i can't put that on?
The confusion comes from the differences among "can be put on" and "approved" and "recommended."
It is physically possible to mount a wide range of of sizes of tires on any given rim. Just because the tire can be shoe-horned onto a rim does not mean that the fitment is safe, however; in fact, some fitments are outright dangerous.
The Rubber Manufacturer's Association (RMA), to which all of the major tire manufacturers belong, has adopted standards for safe fitments. Fitments that are "approved" in that manner are shown in size charts (and in the sticky in this forum) as a range of tire sizes for a specific rim or as a range of rim widths for a specific tire size. The fact that a specific fitment is approved means that it is
safe, but does
_ n o t _ mean that it is a
good idea. In fact, most combinations of tire and rim that fit a tire to either the narrowest approved rim or to the widest approved rim in the range of rim widths approved for that tire are far less than optimal.
Every tire is designed to function optimally when fitted on a rim of a specific width, which is designated the "measuring width." It is only when mounted on the measuring width rim, incidentally, that the published dimensions are accurate: a tire spec'ed for a 7" measuring rim as a 215 width tire (that is, it measures between 210 mm and 220 mm at its widest point when mounted on a 7" rim) might actually measure as a 225 width tire (that is, over 220 mm) when it is mounted on a 7.5" rim or as a 205 width tire (that is, under 210 mm) when it is mounted on a 6.5" rim.
