Full Version: winter tires
Mazda6 / Atenza > Technical / Performance / Model > Mazda6 1st Generation (2002-2007) > Wheels / Tires
Glocker23
I plan on hitting up tire rack for a set of tires and shitty rims for the winter. I will have them mounted and balanced. my question is if i get them and bolt them on, do I need to re-alaign the car or am I good to go
Glocker23
Also thinking about downsizing to 17's for winter instead of my stock 18's.
Mz6GreyGhost
QUOTE (Glocker23 @ Jul 25 2008, 02:32 AM) *
It may not hurt to have it checked when the winter wheels are installed, but in the four years that I've switched wheels/tires on the 6, the alignment has never been tampered with, and at last check, it's still well within specs.
QUOTE (Glocker23 @ Jul 25 2008, 02:38 AM) *
Find a set of used 17" Mazda6 rims. They fit without issues, and they can be found for cheap.
Glocker23
Ooo. Thats a damn good idea about the Mazda 6 wheels. I like where your heads at...Except for that Red Sox Banner being you're from New York...
pruzink
I plan on putting a set of snow tires on my wife's 06 6i come November. I was kind of disappointed with the limited selection that Tirerack had in this size (215 50 17). I picked up a set of stock alloy rims off of Ebay & will buy a set of snow tires from this website
https://www.tiresavings.com/tireShop.php?action=findCombined
I found that they had the best selection of winter tires for this size. I really do like Tirerack they are very fast & their prices are good, but just to be aware of a couple of things if you do purchase a winter tire/wheel combo from them: 1) There is a good chance that the wheel will come with a plastic sleeve to adapt it to your wheel's size & 2) The offset of the Mazda 6 is different from most aftermarket non-OEM rims, I think the Mazda 6 has a 60mm offset, most aftermarket offsets are about 40mm.
